Vm22 installed and slight bog
Heyy guys I just installed the vm22 put the 110 jet in and underW.O.T it bogs down almost stall but under regular acceleration it’s fine and stops at around 10k rpms is that normal only went the high in the rpms twice only have 32 miles on it
You using the stock intake manifold... or one that came with carb?
What was your stock main jet size? Motocheez on utube... he put the vm22 on his Hellcat. His vm22 came stock with #95 main jet... and he upsized to #98 main jet (w/pod air filter and stock exhaust)... and says it runs great. My vm22 for my Hellcat is in the mail.
'20 TaoTao Hellcat 125 "grommet" '04 Yamaha TTR-125LE '00 Yamaha TTR-90 '07 Kinroad XT200GY Runmaster (sold) '07 KMD GY6 150cc ATV (sold) '07 Kangchao 250cc ATV Monster (sold) Baja Moto DB-30 "Doodlebugs"(x3) (sold) '06 Hi-Bird 200 parts bike (sold) |
Depending on your elevation, 110 seems large. I mean, I'm running a 108 in my gy6 150cc.
Using the stock intake untill I can drill the new one to put that hose on it like the stock
You are fine under part throttle because you aren't utilizing the main jet fully yet. The main jet doesn't really come into play until you are past 3/4 throttle. Below that you are using a combination of needle setting, needle jet, pilot yet, and idle circuits.
Drop to a 105 on the main jet and note the reaction. If the bog goes away, problem solved. If it improves but still acts a bit funky, drop to a 100 and try again.
Tags |
hellcat vm22 bog |
