Old 07-10-2016, 12:55 PM   #1
Hawkwind   Hawkwind is offline
Hawk 250 piston change or bore
just wondering if anyone has changed the bore of the hawk 250 ? If so what size and where to find piston and rings ?
Old 07-10-2016, 01:31 PM   #2
Ariel Red Hunter's Avatar
I suspect (but don't absolutly know) that this engine has been already bored out to quite close to the maximum. That said, there used to be a company, in California I believe, that used to manufacture stepped crankpins for small Honda engines. I do not recall the name of the company, or if they are still around. In theory, stepped crankpins are a poor idea, but I never heard of any engine problems from those modifications. This machine shop did the work in house, to make sure the crankpins were installed correctly. If I recall correctly, they bored the flywheels for an over sized crankpin which was machined for an off center big end bearing. The magic words "stroker crank" is how they were known among the motorcycle gear heads of the day.
Old 07-10-2016, 02:40 PM   #3
humanbeing's Avatar
http://www.chinariders.net/showpost....67&postcount=2
Old 07-10-2016, 02:42 PM   #4
Hawk piston size
I kind of figured that the cylinders were maxed out, I remember hearing about Japanese enduros from the 70's were made a lot more powerful with a larger bore, but if the hawk was bored out from an earlier version of a 200cc design then it wouldn't be possible without designing a different head for the motor.
Old 07-10-2016, 03:12 PM   #5
darmst6829   darmst6829 is offline
http://www.ebay.com/itm/262490844536...%3AMEBIDX%3AIT
Old 07-10-2016, 03:43 PM   #6
pcspecialist   pcspecialist is offline
Originally Posted by darmst6829 View Post
doubt that would fit a Hawk frame
Old 07-10-2016, 04:07 PM   #7
So roughly 18hp for $1000, ouch
Edit $790
Old 07-10-2016, 04:13 PM   #8
humanbeing's Avatar
http://www.zse.cc/Upload/motor/CG250-09500646783.jpg vs http://www.zse.cc/Upload/motor/CB250DG-09475128876.jpg
Old 07-10-2016, 08:54 PM   #9
"It is a direct bolt on replacement for most Chinese dirt bikes running 200-250cc single cylinder air cooled motors."
Old 07-11-2016, 08:30 AM   #10
Kdburtch   Kdburtch is offline
I was wondering this as well. A big bore kit would be a nice addition to these bikes.
Old 07-11-2016, 12:08 PM   #11
I'd like a stroker kit even more.
