05-19-2010, 07:52 AM | #16 | |
Haven't seen on on auction for awile though. |
05-19-2010, 07:56 AM | #17 | |
05-19-2010, 08:09 AM | #18 | |
05-20-2010, 06:18 PM | #19 | ||
ive done so many carb adjustments i couldnt even count it seems after every ride im trying to get the carb just right. i havnt tried re jetting what are you suggestions for that and where i could get the jets for what cost (also which ones to get) also i dont think that it sitting all winter has done much because it did it before winter as well just not nearly as bad. |
05-20-2010, 06:42 PM | #20 |
Sorry if this has been covered I'm not an ATV 'expert and did not read the whoile thread but what about $hitcanning the carb and start over with a compatable Mikuni or Kehin?
Happy to serve. |
05-20-2010, 08:44 PM | #21 | |
05-20-2010, 08:50 PM | #22 | |
On my beast i have done the carb, cdi, UNI filter and the performance exhaust w/ monster muffler, with that combo i had to increase the main jet 4 sizes up from the 100 it came with to a 110, also the pilot jet needed to be bigger, i went from the 20 that came with it up 2 sizes to a 25, my jet needle clip is on the 4th groove down and the a/f screw is at approx 1.5 turns out. Now, if you haven't done the exhaust you may want to try a 105 main jet to help get some more fuel at 3/4 to full throttle which is where you seem to be having the trouble at. You can get jets at most motorcycle shops. Courtesy of weldangrind from another post "For further clarification when searching for Mikuni PZ30 jets, look for vm28/486 (pilot jet) and N100.604 (main jet). These guys have it figured out: http://www.carbparts.com/mikuni/mikuni_tuning.htm#Pilot Jets " |
05-20-2010, 08:54 PM | #23 |
Thanks Wayne. I don't remember writing that.
05-20-2010, 09:06 PM | #24 | |
05-21-2010, 07:10 AM | #25 |
It's either rich, or lean.
Both will cause that problem. You need to get the main jet right first, then you can start with other changes. 2 jet sizes won't do it. A 4-5 (minimum) jet size jump will tell you if you are going the right direction or not. |
05-23-2010, 11:14 PM | #26 |
back from a fairly crazy weekend. chainged the oil before a big trip on the quad and it ran so much better still a little bogging but deffinatly ran better. was havin a blast and then on my way back had some more difficulty. if you wanna know exactly how cheap the metal is on these things here is s perfect example. chain fell off and got all caught up in the front sprocket. as if that wasnt enough the housing for the front sprocket also broke jamming the chain all up in there. after a while of asking my buddies for a tool kit that may be able to take the sprocket housing off i found no luck and was down to plan b... man power! i ripped that sprocket housing off with my bare hands as if it were made of plastic. got back took a linck out of the chain fixed everything up and then realized i left the lights on and now the battery is almost entirely lifeless. not to mention i feel stupid. looks like more work awaits next weekend!
