Inherited non-running AGB-38 Apollo
So my brother in law gave me a non-running 2009 Apollo AGB38, likely a wiring issue since he'd been in it. Everything has been cut so I'm starting from scratch. It has a 4-pin CDI and 5-pin stator. It's electric or kick, but I'm going to eliminate the electric start and make it kick only. Also getting rid of the key.
I'm looking for a wiring diagram if anyone has one. Thanks in advance. Ben |
4 pin CDI ?!
Isn't AGB-38 a full size bike that uses vertical machine (6-pin CDI)? Belly button or Nipples? http://chinariders.net/showthread.ph...033#post311033 Anyways follows what CDI maker says for AC-CDI : Belly button: http://www.sanxin.com.cn/Exhibit/exhview.asp?pid=5 Nipples: http://www.sanxin.com.cn/Exhibit/exhview.asp?pid=9
Its 4 wires, not sure what you mean by belly button or nipples. It is a full size bike.
Anyone know if the killswitch would be normal open or normal closed?
Black & white (SW as CDI maker calls it) wire connected to ground (green wire) = OFF in AC-CDI.
Color code: http://chinariders.net/showthread.ph...783#post229783 === ohm reading for quick test: Cdi: http://www.sanxin.com.cn/info5/index.asp?id=16 | Ign coil:http://www.sanxin.com.cn/info5/index.asp?id=20 cowboy style: Proper test needs peak voltage adapter. Not that difficult to build 1. Google it
#8 | |
That kit has an AC CDI. Did you confirm you have an AC or DC CDI? DC will have single wire to the 2 pin connector and will have 12v +- DC on that wire when the ignition is on and not running.
Got her running! Now about this oil leak, lol
