Old 06-16-2011, 12:13 PM   #16
dsmisfits   dsmisfits is offline
Well, even with the bent needle nose it does not move. Also I am trying to find specs on this bike. I know it is a 2005 coolster but what model? Wht type of frame is it? Also, does anyone else have a weird trans pattern? N,1,2,3,4. So (N) is at the top.
Old 06-27-2011, 03:09 PM   #17
ejcycles   ejcycles is offline
ejcycles's Avatar
Hi dsmisfits
What type of frame is it? The frame is called a "Perimeter Frame".
Thanks, Bruce @ Endless Journey Cycles
"Phone Calls Only" ~330-274-0098~
Hours: Tue.-Fri. 10:00-6:00 Sat. 10:00-4:00 EST.
Dealer for: Lifan, Crossrunner ATVs.
http://www.endlessjourneycycles.net
Old 06-30-2011, 06:04 PM   #18
Thanks for that info on the frame.. I picked up another pit bike, and I need to knwo what website you guys use to look up vins.. Also I cannot find the frame this bike has. Are any of the frames on the two bikes I bought any good?
Old 07-01-2011, 02:46 AM   #19
Try this one: http://www.motoverse.com/tools/vinDecoder.asp
I give that zip tie that's holding the exhaust pipe three minutes.
Old 07-01-2011, 01:29 PM   #20
ejcycles's Avatar
Hi dsmisfits
NHTSA site: http://www.nhtsa.gov/cars/rules/manufacture/
Both frames are OK, I guess it depends how hard someone is while riding & how high of jumps they want to try... LOL They do break as will any Honda frame as I have seen over the years, yes I replaced a Honda XR100 frame because the kid didn't want to tighten bolts every so often as any dirt bike needs. He bent the frames backbone because he lost the lower engine bolt.....
