Old 01-18-2020, 10:21 AM   #1
cratebv212   cratebv212 is offline
cratebv212's Avatar
Oil cooler install
Going to install an oil cooler and was thinking about putting a banjo bolt check valve in it. Anyone think it's neccesary? I may do 2 coolers also.
Shootin' for the moon..................
Old 01-18-2020, 11:05 AM   #2
roundhouse   roundhouse is offline
roundhouse's Avatar
I do not have one and never had a prob. When I do an oil change the cooler is full even after sitting a week. I doubt a check valve would reduce flow but I am OK with out.
Old 01-18-2020, 11:45 AM   #3
Not needed.
2020 Kawasaki Vulcan S
2004 Honda ST 1300
Old 01-20-2020, 11:52 PM   #4
The oil pump does a pretty darn good job of acting like a stopper and keeping the oil from draining back.
Old 01-21-2020, 07:42 AM   #5
diyRdie   diyRdie is offline
diyRdie's Avatar
Megadan, since I just ordered the same cooler as you can I ask what orientation you have your cooler in? With the hoses connecting at the top, side or bottom?
Good judgment comes from experience, and often experience comes from bad judgment.
MY BIKE'S THREAD
Old 01-21-2020, 06:04 PM   #6
At the top. Sump side runs to right fitting, pump side with filter screen on the left. Ideally you want the screen before the cooler, but it didn't work well for what I desired.
Old 01-21-2020, 06:10 PM   #7
diyRdie's Avatar
Thanks a ton megadan!
MY BIKE'S THREAD
Old 01-26-2020, 02:52 PM   #8
cratebv212's Avatar
I just wanted to be sure. Got it mounted and plumbed, now just gotta finnish lowering my fender.
