Old 09-21-2015, 03:26 PM   #1
Atreyu57   Atreyu57 is offline
New to the gang!
Hi all! Pretty excited I found this forum, because I don't have any info on the bike I just got, and there seems to be some great people on here that help out! I just picked a
Wildfire WFG-200LDB for $50 from a yard sale that only has 700 miles on it!!Looks like it has been sitting for some time, but the carb looks great and seems like it just needs some TLC. Problem is, I can't find anything on these bike! No user manuals, repair guides, nothing. Here's what I need to know, and hope someone can help out:
What spark plug it takes, What spark plug wire it takes...where that wire goes , what size battery... and where that battery goes (pretty sure the bracket has been broke), What type of oil is recommended, any info on user manuals or repair guides, and a wire schematic maybe? A couple wires have been cut, and I would like to know what they are for without stripping all the wire harnesses back. Lastly, any info on interchangeable parts with other manufactures would be great!
Sorry if this has been covered, but everything I searched for was from 2008-2010 and all the sites are now closed that were used as references. Thanks in advance for all the help...pretty excited to get this thing up and running with little cost...hopefully
Old 09-21-2015, 11:25 PM   #2
mjstef   mjstef is offline
I believe that bike is actually a Kinroad XT200GY. Wildfire was a private label out of Ohio but i believe they are defunct....
Old 09-22-2015, 11:40 AM   #3
Welcome!
We can likely help you get your bike running. You've already found the best resource for a China bike; this forum.
For starters, do you have an ignition coil? Do you have a welder, or know a sympathetic welder?
Most of use 15W40 oil that is normally intended for diesel engines (like Rotella). It works great, and it's cheap at Walmart.
Please show us pics!
Old 09-22-2015, 12:19 PM   #4
ripcuda   ripcuda is offline
ripcuda's Avatar
Welcome!
From what I found in searched threads... your Wildfire is a "GY2 standard variant china bike. Honda based engine and drive system." Probably very similar to my Kinroad XT200GY (except probably w/o the couter-bal engine).
Oil... RotellaT 15w-40 "diesel" oil. Works great!
Spark plug... NGK DR8EA
Spark plug wire goes from plug up to coil mounted under the gas tank on the right side.
Battery: I bought one of these...(STX7A-BS Powersports Battery - Replaces: YTX7A-BS, GTX7A-BS, PTX7A-BS, UTX7A) on fleabay... works great
Battery Holder: is under left rear plastic cover... black box bolted to the frame. Can see it peaking out in pics in my thread.
Check out my Kinroad link in my signature... to see my bike... with pics.
And here are some threads to read about the Wildfire:
http://www.chinariders.net/showthread.php?t=8227
http://www.chinariders.net/showthread.php?t=8829
http://www.mychinamoto.com/forums/sh...ildfire-Moters
Cheers!
'20 TaoTao Hellcat 125 "grommet"
'04 Yamaha TTR-125LE
'00 Yamaha TTR-90
'07 Kinroad XT200GY Runmaster (sold)
'07 KMD GY6 150cc ATV (sold)
'07 Kangchao 250cc ATV Monster (sold)
Baja Moto DB-30 "Doodlebugs"(x3) (sold)
'06 Hi-Bird 200 parts bike (sold)
Old 09-23-2015, 07:34 PM   #5
You guys a freaking awesome! Found out I don't have a coil pack, but with the info everyone has given me I think I should be able to find the right one unless anyone has suggestions. Thanks for all the part numbers! Going to make it way easier to get everything I need! After ripping into a little more it looks like the last guy was trying to make it a straight dirt bike. Cut wires here and there, removed the bracket for the battery, etc. I do have a welder so I'm definitely going to be making some custom adjustments
Old 09-24-2015, 12:13 AM   #6
Here is another vote for 15W/40 motor oil.
Old 09-24-2015, 12:18 AM   #7
Haha thanks spud! So I can end up using parts off the Kinroad xt200gy? I already found an ignition coil if that's the case.
Old 09-24-2015, 07:51 AM   #8
wilserchinarider   wilserchinarider is offline
As confirmed above, your bike is a GY-2 honda clone. Many, many of these bikes were made from the same parts pile in china and marketed under many different names. Parts for these bikes are readily available, the trick is knowing exactly what your looking for. Ebay is an excellent source, but you need to know exactly what you are looking for, and get creative with the search terms, as they will not be listed by the brand of bike, that really means little to nothing at all.
Ebay search below for "200cc ignition coil" as an example. Most of these would likely fit your bike.....
http://www.ebay.com/sch/i.html?_from...+coil&_sacat=0
perhaps this....
http://www.ebay.com/itm/IGNITION-COI...dcd58d&vxp=mtr
or even cheaper...says "kinroad"
http://www.ebay.com/itm/Ignition-Coi...8ae23a&vxp=mtr
Or for only $12 get a coil. wire and spare CDI....
http://www.ebay.com/itm/Ignition-Coi...7efe9f&vxp=mtr
Old 09-24-2015, 09:30 AM   #9
perhaps this....
Thanks for your help wilserchinarider! Pretty positive I'll have this thing up and purring by next week with all the info I've got now! Here is what it currently looks like...had to strip her down so I knew what I was getting into! Got some wires to tuck, and re-run, but I'm just excited to see her start!
Old 09-24-2015, 09:52 AM   #10
If you have the original 15t / 56t sprockets, you will likely want to consider changing them, at least the front as it is cheap and easy..17/46 below
http://www.ebay.com/itm/151719928903...%3AMEBIDX%3AIT
http://www.ebay.com/itm/161739496711...%3AMEBIDX%3AIT
Old 09-24-2015, 03:00 PM   #11
Thanks again! Love the input and suggestions! I have been reading the exact thing you just said. I am compiling a parts list right now and placing an order tonight . Any other ideas??
200cc, wfc-200ldb, wilderfire
