Old 08-04-2014, 01:51 PM   #1
TheLoneRoger   TheLoneRoger is offline
Solenoid failure
The solenoid blew on my LF200GY-2 a few weeks ago; I managed to get a replacement, which worked for a week or so, then that one went - what might cause a repeated solenoid failure?
Unfortunately, this has coincided with a flare-up of an old knee injury, so kick-starting is a rather painful option...
Old 08-04-2014, 03:11 PM   #2
09Fx200Q   09Fx200Q is offline
09Fx200Q's Avatar
Could have just been a bad solenoid replacement ? Happens some times, same thing happened to me on my lawn mower and the third time was a charm.
Old 08-04-2014, 08:34 PM   #3
I have had issues with the bolts holding the relay down being too loose on my bike. But I have had to replace mine once or twice on my old bike. On my new bike, it was giving me problems with starting (just making a clicking sound when I pushed the electric starter) and I took my seat off, and found the nuts a little loose. Tightened them down and the bike started right up!
Old 08-05-2014, 02:04 AM   #4
[QUOTE=TheLoneRoger;170504]what might cause a repeated solenoid failure?[QUOTE]
The only thing I can think of is high current draw. If the starter took excessive current to spin it, that could take out the solenoid. Battery voltage that is too low would also result in increased current draw, but you'd notice that with very slow cranking.
Holding the starter button on too long could also kill the solenoid.
I'm betting that you just got a bad one.
Old 08-14-2014, 05:56 AM   #5
Thanks for your replies.
The starter was turning just fine and I never had to crank it for long to get it started. Just one day working, the next not, in both cases.
Guess I'll just go for a replacement and cross my fingers...
(funny thing - for years I thought an electric starter had no place on a dirt bike, now I actually miss it!)
Old 08-16-2014, 12:15 AM   #6
I love the magic button. It is especially useful if the engine stalls at an intersection, like with a new rider.
Old 08-16-2014, 01:42 AM   #7
I won't own a bike without the 'magic button." Indeed, one is much safer riding on the street with an electric starter.
Old 08-16-2014, 11:42 AM   #8
katoranger's Avatar
My first car was bought cheap due to no start. The problem was someone didn't tighten the nut on the solenoid.
China solenoids have been bad out of the box.
Old 09-06-2014, 11:32 AM   #9
Just fitted a new one and it blew straight away :(
Any suggestions?
Old 09-06-2014, 02:29 PM   #10
The solenoid failed immediately? If so, has the wiring been tampered with at all?
If the wiring is in good order, perhaps the starter is the problem. They're certainly cheap enough to replace.
Old 09-06-2014, 03:45 PM   #11
The wiring looks to be good. I did find one place where it could have been shorting, but i replaced that when I changed the solenoid. I'll see if I can source a starter, thanks.
Old 09-06-2014, 06:50 PM   #12
humanbeing's Avatar
...I'll see if I can source a starter, thanks.
Std 63.5 CB200 :10T/ CG200 :11T. Don't know what's in ur bike.
Find it in specialist http://shop68808900.taobao.com shop if don't had a clue.
