10-23-2017, 12:52 PM | #1 |
WTB: 56T rear sprocket - 428 - 4 bolt - JTR269
Hi Gang,
I know a lot of folks pull off the larger rear sprockets and put on smaller ones for better on-road gearing. I'm looking to do the opposite and make my enduro better geared for off-roading. My 200 enduro has the 4 bolt rear sprocket... same as used on the Honda CB100/CB125. It's the 90mm bolt-to-bolt with 58mm center hub. It's a JTR 269 type... and I'm looking for a 56T version (might consider the 52T). http://www.jtsprockets.com/catalogue/sprocket/JTR269/ If you have a good condition take-off laying around you'd like to sell... PM me. Thanks!
'20 TaoTao Hellcat 125 "grommet" '04 Yamaha TTR-125LE '00 Yamaha TTR-90 '07 Kinroad XT200GY Runmaster (sold) '07 KMD GY6 150cc ATV (sold) '07 Kangchao 250cc ATV Monster (sold) Baja Moto DB-30 "Doodlebugs"(x3) (sold) '06 Hi-Bird 200 parts bike (sold) |
10-23-2017, 02:00 PM | #2 |
I have a 50 tooth. what are you running on the front?
10-23-2017, 02:22 PM | #3 |
I found this in less than 2 minutes.
https://www.amazon.com/JT-Sprockets-.../dp/B000GU1K8K
10-23-2017, 02:31 PM | #4 | |
10-23-2017, 03:47 PM | #5 |
Winner winner, chicken dinner!
10-23-2017, 05:36 PM | #6 |
Thanks guys. I too have found them new... just seeing if anyone had one they swapped out and weren't using. Anything to save a buck... haha.
I'm currently running 17/46... which is great for the street. But got a bunch of mountain logging roads I want to explore. I have my original 15T front sprocket... and thought a nice big rear gear would give me better climbing power. Cheers!
10-23-2017, 05:43 PM | #7 |
15/50 is nice and low. Way to low for me. I'll probably never put it back on the bike.
10-23-2017, 07:53 PM | #8 |
Toss that 15 tooth back on the front with your 46 rear and see how you like it. A 17/56 combo is pretty much the same ratio as a 15/50 set.
