Old 06-16-2016, 11:18 AM   #16
simonjester   simonjester is offline
simonjester's Avatar
There may be a routing issue but I'm betting on complete lack of lubricant from the factory. This has been this way with CB's for as long as I've been involved with them.
Sorry for the dumb question, but what needs to be lubed on it?
2016 CSC TT250
Old 06-16-2016, 12:06 PM   #17
No dumb questions! Just pass it on afterward.
The cable inside the sheath. Pull the sheath from the bottom (wheel end), slide the cable out, making sure you remember the orientation (which end is the low end), hose it down with carb cleaner or some other cleaner and wipe the muck off, hit it with WD40 and let it dry. Then, grease it and slide it back into the sheath.
These things create a TON of friction twisting inside that sheath with no lube or that gummy crap that they sometimes come with from China. Snaps them in nothing flat.
Old 06-16-2016, 12:58 PM   #18
crimsenblaze   crimsenblaze is offline
Any recommendations on type of grease for speedo cable?
Old 06-16-2016, 01:01 PM   #19
Good copy, mine is worthless. At 7 miles on the odo I have traveled 11 on the gps. And of course the MPH is a joke too. I have damaged it to by over tightning but never worked worth a dam in the beginning either. Want to replace with a electronic that can be calibrated. I always have the Garmin mounted so it's acting as the replacement.
I may give the lube thing another try too.
Old 06-16-2016, 01:08 PM   #20
mq1991   mq1991 is offline
I gave mine a light coat of some wheel bearing grease and it seemed to work great.
http://shop.advanceautoparts.com/p/v...v986/7070009-P
Old 06-16-2016, 01:11 PM   #21
White lithium was always the standard for that and door hinges.
Old 06-16-2016, 02:49 PM   #22
2016 CSC TT250
Old 06-16-2016, 02:50 PM   #23
Wait, isn't that what they give schizophrenics?
2016 CSC TT250
Old 06-16-2016, 07:46 PM   #24
Slopeflyer   Slopeflyer is offline
Slopeflyer's Avatar
Thumbs Up
Got the new cable from CSC today (surprised it wasn't just the inner, they sent a complete cable). Seems to be have some lube on it, but I ended up spraying it down with a chain wax that was highly recommended. Also bent the speedometer assembly bracket down which eliminated the cable pressing up against the headlight assembly. Actually a better view angle now for my height. Took it for a 20 mile spin after. Should be much better now.
Old 06-16-2016, 07:54 PM   #25
dpl096   dpl096 is offline
dpl096's Avatar
and CRs apparently ... meds for me please!
― Thomas Jefferson
Old 06-16-2016, 10:07 PM   #26
hertz9753's Avatar
I have tub of Bel Ray waterproof grease. Would that work for the speedo cable? I don't want white lithium I want aluminum...
Old 06-17-2016, 10:30 AM   #27
I've used any grease I've had on the shelf. You just do a light coating anyway. I usually do this annually. I just did the one on Q about a month ago. It's amazing how it smooths out the speedo needle and makes it rock solid in place. No waggle at all.
Old 06-17-2016, 01:18 PM   #28
Azhule   Azhule is offline
BelRay makes great products, I wouldn't hesitate to use that grease anywhere on my motorcycle including the Speedo Cable, I will say a few other brands have (slightly) "higher drop points" but that's about all that's 'bad' on the BelRay Grease
Old 07-03-2016, 04:07 PM   #29
So what is the optimal route for the speedo cable on the TT250? Would you gents who are more knowledgeable than I be so kind as to share a photo or two to help a newbie out?
2016 CSC TT250
Old 07-03-2016, 04:48 PM   #30
Route it to the most easy, swoopy route that it can go from the wheel to the gauge. No place in particular. You just don't want any tight corners.
I routed it like that....and pulled, cleaned and lubed the speedo cable before it even hit the road and it appears that the TT250 made a liar out of me! It let go on this mornings ride with about 90 kliks on it. :-( This is the first CB speedo cable I've had snap.
Time to contact Ryan!
