Bashan Storm 250 upgrades
I recently finished building my Bashan and want to begin exploring upgrades. For starters I want to remove the catalytic converter by replacing the muffler pipe with this: http://parts.powersportsbest.com/ind...-08-250cc.html
Also, I have the standard PZ30 carb and certainly wouldn't mind slotting the screws to remove the bowl and changing the jets as needed but I can't seem to find much info on jets for the PZ30. Conversely there seems to be a significant amount of info. on the Mikuni carb clones. Would I be better off just purchasing a Mikuni VM 26 and a 115/30 jet configuration as I'm at approx. 900 ft. elevation? Want to make sure I'm correct, the main jet is Main Jet N100.604/115, not sure of the pilot jet part number? I would like to install a new filter like this one: http://www.ebay.com/itm/Foam-Air-Fil...-/331342807829 I don't want to make these mods all at the same time but in the same respect if I remove the catalytic converter shouldn't I re-jet the carb at the same time? Lastly, any recommendations on how to disable/remove the emissions equipment on the Bashan Storm? |
I was looking at that pipe.. Let me know how it goes.
I'm not certain but the only mod you can do with these carbs is to unbolt it and replace with Micky look alike ![]() I read on this forum (somewhere) about rejetting and disabling the emmissions contraption, basically it was unscrew it from the head and make a blanking plate to put over the hole. Sorry that's a bit sketchy, it is all here somewhere.. you will just have to dig a bit. Let us know your results. ![]()
2014 Bashan Storm 250 Enduro 1998 Harley Davidson Fat Boy 1993 Suzuki GSX600F - Rebuilt 1995 Harley Davidson Chopper build from ground up. 1983 Yamaha XJ900 REBUILT! ![]() 1971 Triumph Daytona 500 - Restored 1987 Yamaha FJ1200 |
#3 | |
You're wise to rejet when you delete the cat and the emissions stuff.
This is my favourite filter: http://www.ebay.ca/itm/BLACK-42mm-45...VW7TXA&vxp=mtr
Also, I'm super curious as to how that head pipe fits and works out. I have a TT 250 coming with the cat/headpipe situation. It was so much easier when they hid it in the muffler, back in the day!
#6 | |
Once I start I'll post some pics and talk about the results. |
i will be getting that pipe in 2 weeks, was going to get it today, but wife said we had to get a pool ... she said i could still get the pipe too, but i want to get a slip on when i get that ... maybe a fmf tc2, but would really rather get a 4 stroke pipe but they are way more cost
#8 | |
#9 | |
#10 | |
I just ordered the replacement exhaust from Powersports Best - $63.00 including shipping. If it shaves a pound or two and improves performance then I'll be a happy camper.
#12 | |
After you change the air filter, carb, jetting, check valve adjustment and NGK spark plug,....the FMF TC2 do their job on the outlet to carry the flow. It noticeably opened up the mid-range and top end on Q, and I had already ditched the cat out of the stock muffler. The TC2 still made a noticable difference. Here's an link to a thread I did by adding a dB Dawg to the one I have on Q. It helped "unsharpen" the sound. http://www.chinariders.net/showthrea...t=15893&page=2
#13 | |
#14 | |
I know this is the Dual Sport Forum but one even fit right on my Rhino without a problem so with a little ingenuity, it can fit most anything. You just may need to have a little bracketing laying around. I added a small piece of the adapter pipe I cut off to the end of the TC 2 on this one to help the noise. Somewhere here is a thread I did of dimpling that piece of pipe to make it "baffley".
"Light a fire for a man, and you heat him for a day. Light a man on fire, and you heat him for the rest of his life." 2007 Suzuki DRZ400S (SM convert) 2009 Q Link XP 200 1967 BSA B25 250cc Starfire 2022 Royal Enfield Interceptor 650 2023 Royal Enfield Scram 411 1948 Royal Enfield Model G 350 Last edited by 2LZ; 12-31-2016 at 03:42 PM. |
#15 | |
