BAYA 250cc - doesn't start
Hi there,
unfortunately my bike doesn't start anymore. The battery is fine, it really kicks the cylinders. But it looks like to strokes just don't react. The funny thing is, I ride the bike every day and it worked all the time perfect. When I started my bike, just a short start and the engine was running. I don't think the cylinders have any damage. Any ideas what it could be ? Is there any major cable that get's sure the juice get's on the strokes ? thx a lot for any little help ! |
Check for spark.
Check for fuel flow at the carb. Report back with that data and we'll help you get it sorted.
Happy to serve. |
checking
ok, I will get the right tools to check the sparks.
Just one thing.. I checked if the fuel works from the tank... never touched the carb... is there anything specific to do to check the fuel flow at my carb ? In the manual I read that there is an ignition coil connected to the sparks. I was thinking maybe the connection is somehow broken .. but don't know where to look... I will check and report back. Thank you so much for every little help, highly appreciated. all the best and till later |
uffff - can't fix it
Hi there,
1. Got new spark plugs 2. Checked the gas tank and connection to the carb 3. Checked the carb still not running. I got new spark plugs, checked also the carb - but nothing. For some reason, it looks like the sparks don't stroke. Are there any cables or electric connections I have to check ? thank you so much for every little help, Bernhard :( |
