Old 08-23-2011, 12:52 PM   #1
KentuckyDonkey   KentuckyDonkey is offline
Options For Modifying A 49cc Scooter
rewgwr v dfbdf dedfgbv
Old 08-23-2011, 01:34 PM   #2
katoranger's Avatar
45 is doable on a 49cc.
The best place to start is with a big bore kit. 150cc engine can be installed too. That would get you to 55 easily.
100cc kit. Everything you need.
http://cgi.ebay.com/ebaymotors/100cc...-/330459445932
You will want to up the carb and exhaust too. 100cc should get you to 45mph.
Old 08-23-2011, 01:35 PM   #3
I don't know how well a 50 will work for your size and 45 MPH...
All I can offer is that a 2 stroke may be faster than a 4 stroke and it may be cheaper to modify.
I also wonder if a guy could put a bigger engine in a 50, maybe a 125cc manual transmission Hondoid? Cheating, but WTH. :wink:
Old 08-23-2011, 01:38 PM   #4
katoranger's Avatar
If you can find a used yamaha zuma it will nearly hit you goals out of the box. A couple simple mods will have one running 55.
Old 08-23-2011, 01:49 PM   #5
BN fgeg tv evgdetrghetdv
Old 08-23-2011, 02:36 PM   #6
The Zuma is a 2 stroke. 8)
http://www.yamaha-motor.com/sport/pr...1/0/specs.aspx
I think there are Chinese 2 stroke 50cc scooters too but I don't know.
Looks like Kato hit the 'Post' button a few seconds before me. That's why my info was somewhat redundant.
Old 08-23-2011, 08:19 PM   #7
katoranger's Avatar
There are a few chinese 2 strokes, but they are hard to find. They use the zuma style engine. Most were produce in the early 2000s.
Old 08-24-2011, 12:06 AM   #8
F desfge fsedfgre dfwwdfbf
Old 08-24-2011, 01:13 AM   #9
Ssdfeda v ewfewrw rethrwgbrg
Old 08-24-2011, 12:16 PM   #10
katoranger's Avatar
The chinese 50cc scooter engine is pretty common on all the same. If you are looking to go fast then find one that has a disc front brake and bigger tires if possible. Replacement parts are easy and cheap.
Some will have 12" wheels and a long case engine. I would go that route and take the engine to 100cc. Use a 150cc carb and jet it down.
The good news is that for a few hundred dollars in go fast parts you will have really hot scooter.
Old 08-24-2011, 01:52 PM   #11
Sdqwer v dsfgve etgre
Old 08-24-2011, 05:43 PM   #12
katoranger's Avatar
You can also up gear them.
Old 08-24-2011, 08:00 PM   #13
Sfdwefde fwrf vfr dfsvdfdf
Old 08-24-2011, 10:10 PM   #14
katoranger's Avatar
Either one will be fine. I think the disc brake is more important.
Tire sizes.
http://www.chinariders.net/modules.p...=111114#111114
Old 08-30-2011, 12:59 PM   #15
Svcsffgw vv erge erb
