Old 07-29-2011, 10:47 AM   #1
cj   cj is offline
Super noob exhaust question...
GY 200....there are 2 pieces that go where the exhaust pipe is attached to the motor. These two pieces are something like a collar, or flange, or spacer with a lip on one end.. They obviously go around the pipe, but not exactly sure if the lip side of these "collar pieces" goes to the motor side or to the "pipe" side. I apologize for my lack of proper parts terms. I thought I had these pieces installed right...but when I finished tightening the nuts the pipe and these "collar pieces" are still loose. Which way do I install these parts, and what are they called exactly? Thank you!
Old 07-29-2011, 10:59 AM   #2
katoranger's Avatar
The lip should be toward the clamp collar I believe.
Old 07-29-2011, 12:08 PM   #3
ejcycles's Avatar
Katoranger is correct.
Old 07-30-2011, 09:25 PM   #4
cj   cj is offline
Its a done deal. Thanks doods!
Old 08-05-2011, 12:12 AM   #5
Originally Posted by jack520
I like this post ,because I learn some knowledge from it.Thank you very much.
Coach outlet
coach handbags
Welcome to Chinariders. Some of us, like me, can become long-winded sometimes, but the good intentions are always there.
