Old 07-22-2011, 09:57 AM   #1
katoranger's Avatar
Taotao 50cc scoot this time. needs more than a thumb
Well I have another 50cc to fix. This one came with a leaking carb and no spark.
The red/black wire from the stator to the CDI had been pinched in the frame. Repaired that and then stick no spark. I suspected the CDI, but din't have a spare so I tried another coil. Got spark.
Yesterday no carb, CDI, and coil arrive. Put it all together take it for a ride. Rode about 1/4 mile and it died. Restarted by difficult. Then no spark at all again.
Tried swapping coils, cdi, still nothing.
Tested stator 81VAC at CDI. Nothing at coil.
Tested trigger/pickup coil. 0.1VAC This is my suspect. Reading says I need at least 0.5VAC to trigger the CDI.
So now it looks like I need to replace the trigger coil and stator.
Found some good help over here.
http://chinesescoots.forumwise.com/c...hread9545.html
Old 07-22-2011, 12:15 PM   #2
I'm no expert here but as I recall symptoms like this can be caused by an excessive gap from the rotor to the trigger coil. Maybe that or some debris is causing the problem?
Old 07-22-2011, 04:35 PM   #3
That's what I'm thinking. That, or excessive corrosion inside the flywheel.
Old 07-23-2011, 09:59 AM   #4
katoranger's Avatar
I am not sure what the problem wa, but yesterday I checked the connectiosn again and it is started up and worked flawlessly.
If it comes back I will open up the flywheel cover and see what is going on.
Old 07-23-2011, 10:51 AM   #5
katoranger's Avatar
It quit again.
Old 07-23-2011, 12:33 PM   #6
Yeah, it's rare for those automatic repairs to last.
When I found corrosion inside of a flywheel, I sanded it off and then rubbed in some WD-40 to help protect it.
Old 07-23-2011, 02:24 PM   #7
katoranger's Avatar
I think that is what I will try next. I believe I have the correct flywheel puller.
This may be a good excuse to buy one of those electric impacts.
I told him that I didn't think it would last. New stator assembly is $25.
Old 07-24-2011, 12:10 AM   #8
I think $25 is a great price for a new stator. Does this price include the pickup coil? How old is the scooter?
P.S. I could use an inexpensive, electric impact driver. Which model are you thinking about purchasing, and how much does it cost?
Old 07-24-2011, 01:58 PM   #9
Reveeen   Reveeen is offline
Scrappydog sells just the pick-up ($12), or stator. I bought a stator there, it came fast, and appeared to be the same as original. Watch the pictures carefully!
Old 07-24-2011, 11:46 PM   #10
katoranger's Avatar
I only need the pickup. The stator is working fine.
Spud, the scooter is pretty new. I think he bought it over the winter. About 700kms.
Haven't decided on an impact yet. Harbor freight has some. It would be easier than dragging my little compressor out and getting it setup to remove one nut.
Old 07-26-2011, 02:03 PM   #11
I am told those 12V roadside emergency type impact guns will do the trick, probably not much good for anything else, but you know?
Old 07-26-2011, 02:04 PM   #12
katoranger's Avatar
I got it back today. Only 0.2VAC from the trigger coil. Fortunately another coworker had ordered one and didn't need it. I will pick that up today and hopefully have this scoot going tomorrow.
Maybe I will take pics. Have a kodak that needs some testing.
Old 07-27-2011, 12:49 PM   #13
katoranger's Avatar
New scrappydog trigger coil and still no spark. I only get 0.2vac on the trigger coil.
Flywheel is nice and clean.
Old 07-27-2011, 01:00 PM   #14
Damaged or broken wire? Perhaps something is getting pinched by the case? Low battery voltage? Corroded connection somewhere?
I don't really know, just thinking...
Old 07-27-2011, 01:12 PM   #15
katoranger's Avatar
Everything is clean. The battery spins it easily. I am wondering if it is a stator problem.
I don't see any pinched wires. Can't locate my flywheel puller either.
