Old 05-11-2007, 01:52 AM   #1
hunter   hunter is offline
need to know if i can get more speed with sprocket with viva
I am dissapointed in the speed with stock viva 50mph winding alot more than i like anyone that can help me with sprocket conversion? thanks
Old 05-11-2007, 01:57 AM   #2
jkomp316   jkomp316 is offline
Send a message via AIM to jkomp316
read the stickys
Old 05-11-2007, 08:09 AM   #3
frostbite   frostbite is offline
...and the FAQ
Frostbite
"The beatings will continue until moral improves"
Old 05-11-2007, 09:13 AM   #4
deputygene   deputygene is offline
I don't know what the Viva bikes have in the way of sprockets, but 50mph (speed checked by car), wound out, was all my Tank would do with a 50 tooth stock rear sprocket. I just got in a 44 tooth sprocket, hope to get it put on next week and I will let you know.
Old 05-11-2007, 11:46 AM   #5
viva2006   viva2006 is offline
I have a viva also, need to change to a 44 tooth sprocket from dennis kirk. I personally would change the chain while your at it also. I didn't change my chain, but have adjusted it 3 times in 700 kilometers. They strech real quick. you don't want the chain too tight, keep it loose with about 1 1/2 inch or 2 of play while sitting on the bike.
Old 05-11-2007, 05:32 PM   #6
justjoe   justjoe is offline
I've put the 44t sprocket from Dennis Kirk on my Viva and now 60mph is a good cruising speed (indicated 60mph) and I guess I could get 70-75 on a level road. I wonder if the motor would pull a 35t sprocket?
Old 05-11-2007, 06:23 PM   #7
Ridgeline   Ridgeline is offline
Could you give me your RPM,s at 60 mph with the new 44 tooth so that I can add it to the sprocket survey?
Dan Gagne
Ridgeline Rod & Reels
Old 05-11-2007, 07:53 PM   #8
shammash55   shammash55 is offline
Send a message via AIM to shammash55 Send a message via Yahoo to shammash55
i had to put a 46 on mine and i get 50 at 7k,and i bought it thru bill at endless journey.
it takes the insane to keep the world sane
Future 2015 csc rx3
Old 05-12-2007, 12:12 AM   #9
Joe
what chain do you need with the 44 tooth sprocket? thanks
Old 05-12-2007, 12:24 AM   #10
TheOtherRide   TheOtherRide is offline
Send a message via Yahoo to TheOtherRide
This is where you have a choice...upgrade to a 520 chain with new front & rear sprockets, or stick with your 428 chain and upgrade just the rear sprocket for now. You can get any number of teeth with either setup.
I chose to just get a rear sprocket for now, but I'm an infrequent rider on a budget. :wink:
~Pauli~
Former 2006 Viva VX200SX owner
