Old 07-07-2011, 02:16 PM   #1
rusche   rusche is offline
Wheel change, 21/18 to 17/17
On my 200GY. Does anybody know if any rims have the same spoke count? If I supply rims and spokes a local joint will do it for $95, not terrible. Or is there any other way I can get 17s for my GY, maybe a cheaper alternative?
Maybe an 18 front for the time being, closer to what I want without all the hassle. Tire availability for said combos? 17/17 or 18/18? Going for a supermotard look. Looking for aggressive dual sport tires, primarily street.
"I'd rather be riding my motorcycle, thinking about God, than sitting in church thinking about my motorcycle."
2004 Travel-On GY150. 'Chinese Chopper'
Old 07-07-2011, 05:57 PM   #2
Re: Wheel change, 21/18 to 17/17
Thank you for starting a new thread on this subject, Rusche. The Lifan front wheel has 36 spokes, which is common for many rims. I don't know the spoke count for the Lifan rear wheel, but I am confident it also employs a common rim.
I ran a pair of 18-inch wheels on my Zongshen 200GY-2, and I think the bike looked good with this configuration.
You will have a better choice of aggressive, dual sport tires, and you conversion costs will be less, if you choose a pair of 18-inch wheels. If you're interested, I have a used, Lifan front hub, and a used, 18-inch rim for sale. I charge $55 to lace, and true a motorcycle wheel. If you're possibly interested in having me build you an 18-inch, front wheel, send me a personal message, and we can discuss the details.
Old 07-07-2011, 07:48 PM   #3
makenzie71   makenzie71 is offline
Wasn't someone just asking about swapping from their 17" to dual sport wheels? I say hit that guy up and just swap.
Old 07-14-2011, 04:40 AM   #4
bigheavy150   bigheavy150 is offline
I have a 2.75x17 and 2.75x16 heavy steel flat black, perfect shape - 2 dings on front 70% tread on tires i want 18" 2.50 18"2.50
Old 07-14-2011, 09:16 PM   #5
ben2go   ben2go is offline
That was me, and I haven't bought the bike yet.I'm planning to buy Barnone's Qlink XF200 and upgrade to 21/18.Problem is,the GY wheels and hubs are different from the XF200.It'd be a no go, unless the spoke count was the same and both of us could get the correct spokes.Then it's just a matter of swapping rims.
Old 07-18-2011, 04:19 PM   #6
Does anybody know of any wheels that will bolt on? Maybe like an XR200 or something? I'm thinkin about maybe just going 18 front, to give that supermoto style, but keep the cost down.
Old 07-18-2011, 04:23 PM   #7
I think someone reported he mounted two Lifan, sport bike wheels on his GY200. If you search this forum, you can find find the thread; it was posted fairly recently. However, these wheels did not employ spokes, so they would not work well for off road applications.
Old 07-19-2011, 03:43 AM   #8
Wild_Alaskan's Avatar
also the rear hub on the lifans employ an less common spoke count, i believe the rim i ended up getting to replace mine was supposed to be for a cr500 or a kx500 can't remember which.
Old 07-19-2011, 09:07 AM   #9
There's a dozen different hub types, but 90% of them have the same OD bearings. Swap bearings and spacer and you should only have to worry about caliper clearance. Neither here nor there, though.
Old 07-19-2011, 10:23 AM   #10
I kinda agree.Bearing ID is the critical part and hub width.No matter what hub is used,every thing from the spacers,brake assembly,sprocket carrier,and hardware will be needed.Then the hub may not be able to use the correct tooth count sprocket, or the correct chain type sprocket may not be available for the hub.I would really wanna be able to buy cheap off the shelf sprockets.
