Old 06-30-2011, 07:53 PM   #1
daddy469   daddy469 is offline
Sprocket cross reference
I'm looking to get a 14 tooth sprocket for my Lifan and was wondering if anyone had a good source for cross referencing PNs. The PN I have is from Sprocket Specialists, but I wanted to look into other brands.
The PN is: 568X-14
I get that the 14 is the number of teeth, but is there any rime or reason behind the part numbers?
Thanks a bunch!
Daddy 8)
The Great Eye is ever watchful
Old 06-30-2011, 08:47 PM   #2
makenzie71   makenzie71 is offline
http://www.jtsprockets.com/
If you can tell me what other bikes your stock sprockets will fit you can cross reference it on jt sprockets and get any size you want...and they're pretty affordable.
Old 06-30-2011, 11:01 PM   #3
humanbeing's Avatar
JTF259 is the "de facto" parther for these (428) chinese Honda clones
Old 07-01-2011, 12:13 AM   #4
OK, so a JTF259 is a confirmed fit then? I found an actual sprocket diagram with measurements and it 'looks' right, but oh what a difference a mm can make.
http://www.blue-oil-france.com/images/jtf259.jpg
daddy 8)
Old 07-01-2011, 12:19 AM   #5
JTF259 would be the 428 sprocket.
Sprocket specialists have a funky part number system. I would just buy the sprocket off eBay.
http://cgi.ebay.com/Sprockets-Daelim...item35a549713e
Old 07-01-2011, 06:04 AM   #6
humanbeing's Avatar
daddy 8)
the 5mm is jtf328
Old 07-01-2011, 08:56 AM   #7
Barnone   Barnone is offline
Barnone's Avatar
Just in case you do not know about
http://www.jtsprockets.com/61.0.html?&L=0
Go there and plug in JTF259
Old 07-01-2011, 09:01 AM   #8
Thanks for all the info fellas. I wish there was a way to search all sprocket vendors by spec, and not by make/model number. If you take 4 of the common Honda bikes and go to bikebandit, it seems like all 4 will have a different answer for a front sprocket. I do not have a caliper, so I would like to use less shotgun and more fact when I get around to ordering.
Daddy 8)
Old 07-01-2011, 11:23 AM   #9
You don't need a caliper for sprocket measurement. A simple metric ruler or tape will do.
Old 07-01-2011, 01:47 PM   #10
ejcycles's Avatar
The JT sprocket # JTF259 will not fit any Lifan or American Lifan Dual Sport / Enduro motorcycle.....
Old 07-01-2011, 04:34 PM   #11
I seem to remember there being something about that sprocket that was wrong. I think I even read it on these formus somewhere. I just wish I knew which measurement was wrong for my own benefit - trying to learn something new every day
Daddy 8)
Old 07-04-2011, 04:17 PM   #12
I've been looking on and off all weekend, and I still haven't found a confirmed fit. Perhaps I'll just stick with 17 x 46 . . .
Daddy 8)
