Stiff Clutch
My clutch lever is really stiff and always has been. Is there any way to make it more loose and easier to squeeze?
2008 Ricardo (Hi-Bird) 250 Enduro Dirt Bike |
Sounds like it's time to lubricate the clutch cable. If your throttle feels a little tight, or sticky, the throttle cable may need lubrication, too. Youtube has videos on how this is done.
I use a cable luber for that job. It's a cheap and effective tool, and I use Maxima Chain Wax as a cable lube.
Ok thanks!
Is that the only way to lube the cable, with the tool?
No you can sit there & drip oil down the cable till it comes all the way through or make a paper funnel tape the bottom to the cable casing at the top & put the oil in that way. You also want to make sure the cable is routed the correct way so it isn't kinked... A kink in the cable will make it very difficult to to move.
Indeed, a cable luber is not the only way, but it is the fastest. The tool is very economical.
I have never seen a cable luber but i know what they are. I just unhook both ends and use a straw to apply and work the cable back and forth for 3-5 minuets and keep a steady flow of oil, it will suck it down pretty quick and i have constant black spooge at the other end so im sure its working its way through. I use my old motor oil.
I have this type with twin screws: Cable Luber
I use Maxima Chain Wax only, because I don't want any build-up between the housing and the cable. If I pick up a used bike, I use the cable luber and some brake clean to fully clean the inside of the housing first, then I follow with Maxima. It works great.
