06-20-2011, 02:15 PM | #1 |
ATV Speed Question
Here's one for you atv folks.
My brother owns 7 acres of basically rolling hill farm land here in Nor Cal. He's been beating up a lawn tractor (and himself) every few years dragging around his tow-behind mower platform. The land has been disked a couple times so the no-suspension ride of the lawn tractor is horrendous.....along with cracking and breaking everything off the tractor after a while. He asked me about the Chinese ATV's and how I thought they'd work. I said that I thought a full-sized 150 ranch-style quad should be adequate but I wouldn't burn up a CV trans dragging it around at mowing speed.....or am I incorrect in this assumption? So, you guys who have the manual clutch/shifting quads....do you think that first gear would be slow enough for this? He only knocks it down a few times a year, so it's not like he can cost-justify a used, 'real' tractor.
06-20-2011, 04:27 PM | #2 |
You can always gear the atv down more. How about renting a real tractor/mower to do the job?
06-20-2011, 11:45 PM | #3 |
I wouldn't even rent. I'd ask a neighbor to borrow theirs.
I wouldn't try to pull a mower with the 150...and CERTAINLY not with a CVT/auto. I wouldn't go any less than the 200's that are floating around, and then you'd have to find a HUGE sprocket. On my HiBird I'm currently running 15/38 gearing and, at idle, you couldn't pull the mower...there's no power at idle. You'd even have that issue with the CVT or auto. If I had no other choice than to use my quad, then I would be looking a 90 tooth rear sprocket...and even then I would have to have it adapted because lord knows you can't find sprockets that bike in our bolt patterns. Plus, for what it would cost to buy a quad to pull the mower he could hire someone to come and blade the entire property so that using a lawn tractor is feasible.
http://www.duncandesignsstudio.com/justinsoddprojects/ |
