Old 06-12-2011, 12:08 PM   #1
sallzy   sallzy is offline
changing a 56 tooth rear sprocket for a 45 tooth sprocket
So I just got my new 45 tooth rear sprocket from bruce at endless journey cycles along with a 428 heavy duty chain. didn't really need the chain but I figured now would be the time to do it.
first thing was to get it up on the lift strapped down and remove the front sprocket cover.
next unhook brake linkage and backing plate support.
remove the chain guard, loosen up the chain tensioners and remove the axle.
reove the snap ring and sprocket bolts.
install new sprocket,snap ring and torque the nuts. I applied lock tite just to be sure and also put a dab on the end of the nut to see if it loosens up.
here's a picture of the rear wheel removed with the drum brake assembly and chain adjusters.
I removed the old chain and installed the new one taking off the extra links.
re-install rear wheel in reverse order,adjust chain tension to spec,tighen axle nut, re-install chain guard and front sprocket cover. lower bike to ground and recheck chain tension. if everything looks good, take it for a test burn and crack a cool one. in that order. everything went pretty straight forward and was as easy as I expected it would be. can't wait to see how much difference this sprocket makes in motor revs.
Old 06-12-2011, 12:26 PM   #2
Beware that some owners have had trouble with the cush drive bushings and studs. The fix is to use Honda replacement parts, which are cheap and plentiful.
Old 06-12-2011, 12:45 PM   #3
Re: changing a 56 tooth rear sprocket for a 45 tooth sprocke
Originally Posted by sallzy
So I just got my new 45 tooth rear sprocket from bruce at endless journey cycles can't wait to see how much difference this sprocket makes in motor revs.
Bruce comes through once again!!
You will see a world of difference--not a huge leap in top speed, but it will cruise at 60 mph (indicated) with much, much, much less effort than the stock one did at 45-50 mph (indicated) !! 8)
Old 06-12-2011, 01:25 PM   #4
chrisdigital20   chrisdigital20 is offline
Dude in the pic of the bike back together, you have the outer washer plates on upside down, fix it!!
Old 06-12-2011, 02:32 PM   #5
good catch chris. my 7 year old had started "helping" me put it back together and I must have snoozed that part. It might have something to do with a bazillon questions I was getting...
Old 06-12-2011, 02:35 PM   #6
weld, what kind of issues are people having with the cush drive bushings?
Old 06-12-2011, 03:52 PM   #7
IIRC, the bushings come apart and allow the studs to bend or break. The Honda bushings are much better quality.
Old 06-12-2011, 08:44 PM   #8
Mike_51_deluxe   Mike_51_deluxe is offline
How is it?
SO how is it? I am going to get a smaller rear sprocket as soon as I can. I wasnt sure which size to drop down to. I have a 56 now, so is 45 the way to go? Id like to be able to do 60 comfortably. Right now I can start off in second no problem, not sure if that helps.
Old 06-13-2011, 01:31 AM   #9
Thanks for posting the great photos, Sallzy! Please let us know how you enjoy the smaller rear sprocket.
Old 06-13-2011, 04:33 PM   #10
If it will ever stop raining up here in the northeast I'll let you guys know how it runs. I was able to take it for a quick burn ( between rain showers ) and it made a world of difference on cruising speed. I'd also give Bruce a call at endless journey cycles if your looking for a sprocket. Great guy to deal with and super fast shipping.
Old 06-14-2011, 01:30 AM   #11
Re: How is it?
Mike, immediately get a 45...do not pass 'Go', do not collect $200 My old Jetmoto enduro could cruise at (an indicated) 60 very comfortably once I replaced the rear sprocket with a 45 (although it might have been a 44 )
Before that, the bike sounded like it was ready to explode at anything approaching (an indicated) 50 mph
See if Bruce has any more of the 45's
Old 06-14-2011, 11:47 AM   #12
ejcycles's Avatar
I will have some more this week I have them on order.
Thanks!
Old 06-14-2011, 12:09 PM   #13
45 tooth
Thanks, thats exactly what I needed to know. My bike does 60 pretty well actually, and Im really really really surprized at the lack of shcky, scetchy, vibration. Its not bad at all. Once I get the 45 tooth on there this thing might just be a Highway dream machine. Only time will tell lol.
Thing about mine is that its a really different bolt pattern, and I really want to get it before this weekend so I can take a road trip. How do I get a hold of Bruce? Anybody have a number?
Thanks
Mike
Old 06-14-2011, 12:18 PM   #14
Im dumb
lol, I see that Bruce posted above me with his contact. Derrrr, Im a lil slow at times lol.
Old 06-14-2011, 11:38 PM   #15
What Honda bike do i want to order cush drive bushings for to replace my sloppy ones, help!!!!, 08 shinearay 200gy I
