Old 05-19-2011, 12:56 AM   #1
hotkarl   hotkarl is offline
No Spark on Zongshen
There's no spark on my viva (zongshen) 200cc. I changed the CDI, but that didn't change anything. Next I'm probably going to change the coil, but before I buy more parts, does anyone have a wiring diagram perhaps? It's under 100 miles so I just have no idea what would go bad.
Old 05-19-2011, 01:35 AM   #2
Re: No Spark on Zongshen
The Viva 200 is a hondoid, and has a different engine than the Zongshen 200GY-2. If you search this forum, and/or check the Tech Sticky at the top of this forum, you will probably find a hondoid wiring diagram thaw will work for you bike.
If the CDI unit is good, I would start troubleshooting at the spark plug, and work my way back to the stator. I would also check to make sure I had a good ground connection to the frame, and the kill switch was in good working order.
Old 05-20-2011, 08:17 PM   #3
shaneswigs   shaneswigs is offline
how do i go about checking the kill switch?
Old 05-20-2011, 11:47 PM   #4
You need to check the wiring diagram to make sure, but a lot of the kill switches are wired to ground the CDI unit when the kill switch is turned "off." If this is the case for your motorcycle, the kill switch is not causing the problem.
Old 05-21-2011, 12:32 AM   #5
makenzie71   makenzie71 is offline
The kill switch is almost invariably black with a white stripe. To check your kill circuit turn the key ignition on and the kill switch to run, then check for continuity between the kill switch wire AT THE CDI and any ground. You should get infinite resistance. If you measure anything else, either the key ignition or your kill switch is bad.
You also need to check your signal pulse at the CDI (almost always blue with white stripe wire). You should get a very marginal voltage here while cranking, but there should be some voltage.
To check the coil start by unplugging it and testing for voltage between the wiring harness side and ground while cranking.
Old 05-24-2011, 07:20 PM   #6
Thanks guys I'll take a look. Also, one of the zongshens came with a 200gy parts and maintenance guide, the other one looks like almost a different brand.
Sorry for the delay, but how would I go about checking the stator?
Old 05-24-2011, 07:28 PM   #7
Here is everything you need to know, I think:
http://www.dansmc.com/electricaltesting.htm
Old 05-24-2011, 07:30 PM   #8
Thank you!
