Old 05-10-2011, 11:17 PM   #1
Guy77   Guy77 is offline
GIO T2 Rebel Carb is leaking gas
Just bought a GIO T2 Rebel ATV new from dealer.
Its got a 125 cc engine starts and runs fine.
Problem is once I stopped riding it the carb starting leaking fuel out of pipe attached to bottom of carb. This lasts for hours.
Anyone have an idea what this might be?
Thanks in advance
Old 05-10-2011, 11:48 PM   #2
My Beast was doing the same thing. I took the bowl off the carb and blew the float needle seat out and it seemed to stop for a while... Then it started leaking again . Reminds me... I still have to install a fuel shutoff on mine. On mine I suspect it's just a bit of crud left over in the tank from manufacture that's keeping the float needle from closing tight... Guessing maybe a fuel filter would remedy that? I'll let others more knowledgeable in the workings of the carb give better answers
Old 05-11-2011, 08:57 AM   #3
Thanks for the info.
BTW if you were to put a gas cutoff were would you place it. Right after the gas tank or closer to the carb?
Thanks
Old 05-11-2011, 09:34 AM   #4
FosterVS   FosterVS is offline
Re: GIO T2 Rebel Carb is leaking gas
Thanks in advance
Umm... is the bowl drain screw tight? This would be directly above that hose.
Old 05-11-2011, 10:43 AM   #5
It sounds like a leaky needle and seat like Stew says. I'd take the carb apart and clean it, and install an inline valve (wherever it's convenient for you) along with a quality filter. I had a China filter come apart once, and I'm thankful that the engine wasn't running at the time. 8O
Like Foster says, make sure the drain is tight, although if it's a leaky needle and seat, you're not likely to see much fuel out of the hose while the engine is running.
Old 05-11-2011, 10:44 AM   #6
Also, use the opportunity to install quality fuel hose. I use the blue snowmobile stuff, because I can confirm fuel flow and it remains flexible in cold weather.
Old 05-11-2011, 01:17 PM   #7
Thanks!
I am going to check the screw on the carb when I get home tonight.
Old 05-11-2011, 08:22 PM   #8
waynev   waynev is offline
Yep i agree with crud in the needle and seat causing it not to close/seat properly when the bowl is full of fuel, a simple carb clean and a good fuel filter will keep this problem at bay.
Old 05-11-2011, 10:05 PM   #9
Weldandgrind you were right , it does not leak when its running just when its turned off. I guess then it will need a carb clean.
I am going to let the dealer in Oshawa do it since I got warranty.
Down the road I will definately have to learn this myself.
Anyone know where to get a better fuel filter for these ATV's.
Thanks again guys.
Old 05-11-2011, 10:10 PM   #10
Just hit up a local name-brand bike shop. Look for Made in USA or Canada.
Old 05-11-2011, 10:21 PM   #11
Yes, while running that extra fuel will get sucked into the motor, when off it overfills the bowl and then out the overflow, it's the gravity effect as the tank is higher than the fuel bowl and if the needle won't seat it just slowly drains the tank thru the overflow tube.
Old 05-11-2011, 10:34 PM   #12
I will definately learn how to fix these things myself down the road. Local bike shop wanted $90 /hr and min 2 hrs to do this work. When warranty is up I will doing my own!!
Maybe I will by an extra carb and tear it apart and put it back.
Old 05-11-2011, 11:09 PM   #13
I have a spare GIO Beast OEM carb if you want to mess with it, i'll never use it again and would feel bad trying to sell it ( it's a crappy carb), if you want it just PM your address and i can send it to you for the cost of shipping, and since your only 2 hrs. away it should be cheap.
Old 05-11-2011, 11:23 PM   #14
You are a good man, Wayne. Getting to know guys like you, and many other good guys, is one of the reasons I like to hang out here.
This is good because I'm gonna sell off my last Chinabike!
Old 05-12-2011, 01:25 AM   #15
Guy, page four and five of this thread will give you a little insight into the carb: http://www.chinariders.net/modules.p...r=asc&start=45
Getting ahold of Wayne's old carb is a good idea for practice.
