04-25-2011, 11:28 PM | #1 |
Rust Paint Atv
Certain parts on the atv are beginning to develop rust, especially the welding spots..
What do you forum members usually do in order to prevent rust on atv. Do you normally sand down certain spots and paint it with anti-rust paint? I was thinking of painting certain important welds with anti rust paint. My atv muffler mounts already came off, leaving me no choice but to purchase a performance exhaust from giobikes... |
04-26-2011, 01:15 AM | #2 |
No rust so far, but I'd clean it with a wire wheel and then coat it with Tremclad and a disposable foam brush. I get 'em by the bag at the Dollar Store. Much easier than masking and spraying.
Did you ever buy a welder?
04-26-2011, 08:43 PM | #3 | |
Re: Rust Paint Atv
04-26-2011, 08:58 PM | #4 |
sounds like some one needs a welder, if the frame is cracking at the joints its best to do some rewelding to reinforce those areas.. then spray it with some paint and call it a day
200cc beast replica,carsoli cdi,performance coil,fmf powercore 2,uni air filter,hour/tach meter,jetted mikuni carb,msr bars,moose racing grips,yz250f clutch perch,D.I.D chain |
04-26-2011, 10:12 PM | #5 |
I never got around to buying a welder. Problem with purchasing one is the fact that I don't even know how to use it, since all I have used before was oxy/fuel welder. Tanks are expensive...so only option is mig or arc welder, which I don't know how to use.. :(
