04-11-2011, 12:33 AM | #1 |
rear wheel replacement options
gio beast wheel chart.. these wheels match the beast rear wheel bolt pattern..
oem wheel size/ make/model oem tire size bolt pattern ATC 200X, 86-87 (R) 22x10x9 9x9, 4/110 TRX 200, 90-93,96-97 (R) 22x10x8 8x8, 4/110 TRX 200SX, 86-88 (R) 22x11x8 8x8, 4/110 better yet as it turns out there are ALOT of name brand quads that run the 4x110 bolt pattern.. this site has a listing of i think every single quad made by all of the name brand companies listing all of the information above for all quad models.. http://www.mud-throwers.com/atv_wheel_chart
200cc beast replica,carsoli cdi,performance coil,fmf powercore 2,uni air filter,hour/tach meter,jetted mikuni carb,msr bars,moose racing grips,yz250f clutch perch,D.I.D chain |
04-11-2011, 12:54 AM | #2 |
Thanks Mike, that's good to know. It might be cheaper to buy take-offs on CL than to buy new stock tires for the Beast. Plus, there is an opportunity to get a larger wheel.
04-11-2011, 01:11 AM | #3 |
so far from going over the listing in the link i posted, honda and kiwi are the 2 that run the 4x110mm bolt pattern on the rear wheel..
and ya weld i was thinking more of cl finds, if some one happens to see some wheels listed they could check the year, make and model to that list also means that we now know what rear wheel spacers to order should some of use want to kick the rear tires out another inch or 2
04-11-2011, 09:02 PM | #4 |
anyone know the bolt pattern on the mini beast and mini atv? even a replacement hub that would have a 3 or 4 bolt pattern from one of the major brands? thanks
04-11-2011, 10:20 PM | #5 |
get a digital vanier (spelling) caliper.. its a electronic ruler and make sure it does mm.. measure the distance between stud holes on the hub... in the i linkest that site has all the information on how to properly measuring the bolt pattern and it only takes a few seconds to get the measurments
04-12-2011, 10:16 AM | #6 |
how about the front. i have a new beast 2010 and the front has disks,and the pattern looks the same as the back
04-12-2011, 10:38 AM | #7 |
That's good to know, johnwayne. I hadn't realized that the new Beast has disc brakes in the front. The front drums and rear disc stop our Beast just fine, but a disc front system would likely be easier for my wife. Does the brake hose split after the master to connect to both wheels? Got a pic?
04-12-2011, 12:14 PM | #8 |
yes it does split. i will take a few detailed pics of the 2010 as soon as i make it to the shop n wash all the mudd off it.
04-12-2011, 05:53 PM | #9 |
hmm i might be ordering that 2010 beast front dic setup
