04-27-2007, 12:36 AM | #1 |
what oil do you use?
My manual told me, and I Quote.
"Use 10w 30 gaolene or better. Do not mix the two!" I have no idea what that means. I changed out my shipping oil like the prep thread said. I used 10w 30 oil. Any suggestions on what I should have used? What do you use? If there is a thread like this somewhere, please point me to it and end this thread. New2riding and chinariders. |
04-27-2007, 12:46 AM | #2 |
http://www.chinariders.net/modules.p...&highlight=oil
This may help. The search function on here works great, but it definitely helps once you've been around a little while & see what stuff people have already discussed. There's some great info in the "sticky"s at the top of the categories, too. I read through all of them, the tech info, parts ref, etc., before I even got my bike; it didn't all stick with me, but then I had an idea of what info was available (like carb needle adjusting!)
~Pauli~ Former 2006 Viva VX200SX owner |
04-27-2007, 07:25 AM | #3 |
10w30 if fine for break-in. You will want to drop it again soon anyway. I changed mine out at 25 miles, 100 miles and 250 miles. I will drop it again at 500 and switch over to Mobil 1 synthetic. I think most of our bikes recommend 15w40, which I have only ever seen made for diesel trucks :? . I am running 10w40 and will either run that again in a synthetic or 15w50 for Summer driving.
04-27-2007, 08:44 AM | #4 |
Thanks for pointing out that thread, Princess. I looked at the label late last night. Guess what the newb did, yep SAE with friction reducer. I'll drop it out and go 10w 40 without SAE. I did do a search on oil but came up with 18 pages of threads on oil. I never saw the thread you pointed out. Live learn and ride
04-27-2007, 12:26 PM | #5 |
I think it is motul 10w40 mineral oil I have
04-27-2007, 01:07 PM | #6 |
since these are honda clones i thought it would be ok to use honda oil. seems fine for now. my dealer had put yamalube in it at first they are a yamaha dealer also.
06 american lifan 200 gy-5 |
04-29-2007, 01:45 PM | #7 |
I use Harley-Davidson 20W-50 in mine. Leftover from my Buell days! After that runs out, I have some Redline 20W-50 full synthetic. I never thought I'd have another bike to run this crap in. When it's all gone I'll probably switch to Mobile 1.
2013 Jeep Wrangler Sahara MOAB 2005 BMW E53 X5 2011 Schutt Industries LTT-HC LQG trailer 2017 Coleman CT200U 1978 Yamaha SR500E 1979 Yamaha XS650 Special II |
04-29-2007, 04:11 PM | #8 |
Any Motorcycle Approved 10w40 or 20w50 will work Ok. Do Not run a Synthetic untill the engine is completely broken-in.
Do Not use standard car/automotive oils, as they are not made to lubricate the transmission and wet clutch, and they will foam in the top end causing engine damage.
04-29-2007, 05:04 PM | #9 |
After breakin, is there any reason to switch from mineral to synthetic?
04-29-2007, 05:15 PM | #10 |
Sure, Synthetic lasts twice as long, keeps the engine running cooler due to better lubricating properties, gives better fuel milage for the same reason, etc. etc. {Amsoil} It's the only Synthetic I carry at my shop. I run Amsoil in everything that I own the best there is! I have a 1991 GMC C-1500 with 320,000 miles on it, doesn't smoke a bit, runs great and the engine has not ever beem torn down. It drips a little from the rear main seal but after this many miles I guess it would. Here read some about it... http://www.amsoil.com/
Again here too, Motorcycle Synthetic Oil Only!
04-29-2007, 05:45 PM | #11 |
Thanks for the info Bruce
04-29-2007, 11:36 PM | #12 |
read towards the bottom here: http://www.calsci.com/motorcycleinfo/Oils1.html
Roketa DB-07a HID Headlight |
04-30-2007, 08:11 AM | #13 | |
I should probably change the oil in the bike since it has sat all winter. Guess its off to Wally World to see if they have some of the Shell Rotella-T Synthetic. Also might pick up some extra and try it in my girlfriends 2.5 Turbo Subaru engine ('06 Forester).
06 Lifan LF200GY-5 |
04-30-2007, 09:49 AM | #14 |
Well I can go cancel that motor oil course I was going to take.
I changed out the shipping oil my bike came with, but I used 10w30 with friction reducers. So i changed it with Canadian Tire 10w40 motorcycle oil. Still waiting for Ins and plates, so can't break in my motor. Sounds like Synthetic is the way to go eventually. I fired up the bike and it wanted to walk slowly forward in first gear, with the clutch pulled in. Afer a couple minutes the walking went away. Is this normal after a change? Newb. |
04-30-2007, 09:54 AM | #15 |
Great read, especially the Synthetic break-in part, as I've said before, my Toyota Camry XLE V-6 came with Mobil 1 right out of the factory and I've never had any problems, BTW Toyota just topped GM in first quarter sales so they must be doing something right but that's another topic...
I broke in my bike with Rotella non-synthetic and shortly switched to Mobil-1 for 4-strokes, no problems with the bike either...
06 Lifan 200 GY-5 |
