Old 03-26-2011, 01:37 PM   #1
bbbdan777   bbbdan777 is offline
hs200gy wiring
i just bought a sl hs200gy (assembly required) and it did not come with any instructions. I managed to get everything assembled, except for the wires in the front by the headlight. I dunno which color wire the kill switchs, brake, and some other colored wires hook into, can anyone help me out. If anyone reading this has this same bike can you help me match up the wires. Ill give more information on the wires if you know.
Old 03-26-2011, 01:45 PM   #2
Welcome!
The dual sport guys who are knowledgeable about your bike will likely chime in.
Old 03-26-2011, 01:45 PM   #3
Thorgram   Thorgram is offline
I had the same issue when I bought mine, no instructions. However the wires were already hooked up. So I didn't have that particular issue.
This thread: http://chinariders.net/modules.php?n...ewtopic&t=4788 has links to some wiring diagrams and may be helpful since alot of the bikes are very similar. Yours looks alot like mine so it may be wired the same. Somewhere I have an image file of my wiring diagram and if I can find it I'll put it up, it might help.
Old 03-26-2011, 02:13 PM   #4
It's a little blurry in the middle for some reason but if you save it and zoom in a bit you can make it out for the most part. Hope this helps.
Old 03-26-2011, 03:51 PM   #5
katoranger's Avatar
Got pics? Likely the wiring connectors should only fit one way.
Old 03-26-2011, 07:35 PM   #6
not letting me share my pictures.
Old 03-26-2011, 09:25 PM   #7
katoranger's Avatar
http://www.chinariders.net/modules.p...wtopic&t=11188
Old 03-26-2011, 10:17 PM   #8
This is the general view of the picture
This one is coming from the speedometer
Kill switch male wire and a female wire coming from the light switch (controls headlights)
Two other female wires.
Basically there are 3 male and 3 female wires that are loose , just trying to figure which colors mix and match[/img]
Old 03-27-2011, 12:43 AM   #9
The wide connector in the last pic looks like the common ground for the right and left front turn signals.
Old 03-27-2011, 01:37 AM   #10
ok cool you know which female one the kill switch connects to? is it the black and white or brownish one?
Old 03-27-2011, 02:17 PM   #11
No idea but it would be easy to determine by checking for continuity between the wire in question and ground and operate the switch. Do this with the ignition off, or the negative lead of the battery disconnected.
Old 03-27-2011, 04:47 PM   #12
oh can you explain a little more what i would need to do. Btw i dont have an ohmmeter
Old 03-27-2011, 04:52 PM   #13
Buy a cheap ohmmeter or even a continuity tester at the auto parts store or Radio Shack. You sould find one for $15, maybe less. It is a tool you will use the rest of your life and worth having. Stick one probe in that connector and the other on a bolt or other non painted part connected to the frame. If that wire is for the kill switch when you switch it back and forth the continuity should also go back and forth.
Here's a great article on the subject, and a great online textbook for basic motorcycle mechanics.
Brother Dan is a great teacher, and a faithful Christian as well. I encourage you to read and enjoy the entire website:
http://www.dansmc.com/
http://www.dansmc.com/electricaltesting.htm
Old 03-27-2011, 05:14 PM   #14
ok i think i got it, basically i just use the ohmmeter to measure the two wires and make sure they have the same amount of ohms?
Old 03-27-2011, 05:51 PM   #15
Personally, since it's down to two or three wires, I would just plug and pray. But that's just me.
