Old 03-17-2011, 10:01 AM   #1
JTCAndrew   JTCAndrew is offline
Live Webcam of my Q
Getting ready to Fire up the NEW Qlink XF200 Supermoto. I will be posting the Exhuast video you all have been asking about later tonight or tomorrow. The weather here is perfect. Below is a Link to my Live webcam where you might just cath a glimpse of the event. Ride safe everyone - I'm outta here!
http://www.ustream.tv/channel/Jamestown-Computer-Inc
Andrew 8)
Old 03-17-2011, 10:30 AM   #2
So cool! The sun has washed out the video image a bit, but I can see you prepping your bike. Have fun!
Old 03-17-2011, 10:43 AM   #3
Can you compensate for the brightness? After studying the image a bit, it looks like a US flag is waving in the foreground, but I'm not sure.
Old 03-17-2011, 11:10 AM   #4
weldandgrind Bike fires up But I am having small issue with the carb adjustments. After the bike is warm, and I take the choke 3/4 of the way off and give her anykind of gas she dies right out. Like she's getting to much fuel. Chokes out and dies. So I'm reviewing my carb adjustments now. Any thoughts?
Andrew
Old 03-17-2011, 12:07 PM   #5
That sounds LEAN to me but I'm not sure if that makes sense...
Old 03-17-2011, 12:08 PM   #6
What's the plug look like?
Old 03-17-2011, 01:15 PM   #7
Waiting for a cool down down - In the meantime I did just replace the idle jet with the 35 and That helped a tad bit not much. I am waiting for a cool down to pull the plug see what that looks like then I am going to pull the top of the carb (AGAIN) and put that needle valve back to factory. I have a feeling.....Waiting for cool down 30 -40 minutes....I'll keep ya posted DOC on the Plug....Thanks
Old 03-17-2011, 01:16 PM   #8
Sorry for your frustration but it will be worth it when she runs well, which will be very soon!
Old 03-17-2011, 01:27 PM   #9
katoranger's Avatar
My connection is too slow to view the video.
Sounds like a lean condition.
Old 03-17-2011, 01:44 PM   #10
Since both of you Are leaning toward a lean condition - Any suggestions?
My guess it has to do with moving that damn needle - I got talked into doing from someone else on another forum - I should have waited - No problem I'm going to swap it back to factory in a few minutes.....The live cam should be alittle better now - it is very SUNNY OUT Today and warm! 8)
Andrew
Old 03-17-2011, 01:47 PM   #11
I don't recall. Did you move the clip down to the point of the needle or the other way? Moving the clip towards the point it richer (what you wanted) and vice versa....
Sorry if this is obvious or already discussed.
Old 03-17-2011, 02:13 PM   #12
I had moved the clip closer to the point - I just moved it back to the orig oem position - If this does NOT Work I may have it figured out. The plunger has a plate on the inside there are three holes two are for screws. The other can be covered or uncovered based upon how that plate goes in. I have it uncovered. Which looks to be correct based upon a picture in the portguees manual. Going to put it back togather now and fire it up. We will see! 8O
Andrew
Old 03-17-2011, 02:38 PM   #13
katoranger's Avatar
Since it runs better with the choke on that indicates a lean condition.
Old 03-17-2011, 02:41 PM   #14
Yup...
Old 03-17-2011, 02:42 PM   #15
Andrew
Since you did adjust the needle correctly that may/must be it...
