new chain questions
hey guys is there anything that i am supposed to do with a new chain before installing and using it ?
i mean something like should i soak it in chain oil over night before the install or is there some kind of break in time frame with new chain
200cc beast replica,carsoli cdi,performance coil,fmf powercore 2,uni air filter,hour/tach meter,jetted mikuni carb,msr bars,moose racing grips,yz250f clutch perch,D.I.D chain |
I don't ever soak a chain in oil because I hate when it flings off and makes a mess.
I either ask someone to lift the back end or I place the frame on a block and run the engine at idle in first gear. With the chain spinning, I spray Maxima Chain Wax on either side of the chain (meaning left and right) and ensure good coverage. I do it again at some point during a break in riding while the chain is hot. Be careful with this procedure. Expect your new chain to stretch a little, but a little loose is better than too tight.
sweet, i was thinking of soaking it in chain oil over night then hanging it up and letting the excess drip off of it for a half day to full day then install it.
i ordered a d.i.d. 428 standard non oring chain, in the description from d.i.d. about this chain they said its prestretched so i am anticipating a very very small amount of stretch but not to much..
#4 | |
