Old 03-03-2011, 01:30 AM   #1
mizke   mizke is offline
how to measure chains
i can get cheaper chains online then i can at the local shops. but i have to know what size chain to order..
so far all ive been able to measure is the chain and sprocket pitch which is 1/2in..
does any one know of a website or could post pictures of the exact points to measure and how to take said measurments and get the chain size..
thanks guys
200cc beast replica,carsoli cdi,performance coil,fmf powercore 2,uni air filter,hour/tach meter,jetted mikuni carb,msr bars,moose racing grips,yz250f clutch perch,D.I.D chain
Old 03-03-2011, 06:09 AM   #2
I'm guessing you have a 428 or possibly a 520 size chain, I did find these guides that might help you figure out the right size.
Old 03-03-2011, 09:50 AM   #3
waynev   waynev is offline
Re: how to measure chains
thanks guys
Since your quad is like our beasts then it should be 428 chain, and the 1/2" pitch you measures proves it's either 420 or 428, if your sprokets are around 1/4" thick then you need 428. As for length, they are usually sold in #'s of links, just count how many you have and make sure the chain you order is long enough, you will probably have to cut/break it to the proper length.
Old 03-03-2011, 11:42 AM   #4
ya not worried about getting the right length, i planned on ordering the longest i could and then cutting it down
so after measuring the pitch and between the inner plates what do i do with those numbers ?
guessing i have a 428 then, the inner plates are 5/16 sweet, idk why i was getting so confused over measuring the chain but i think i have it figured out now.. so thats 1 of 3 things to figure out, next up is my head light wirring and then getting my swingarm welded
Old 03-03-2011, 01:20 PM   #5
my sprockets are 9/32, is that close enough to 1/4 to work for a 428 ? i guess worset case if i order the wrong sized chain i could just find some sprockets to fit it..lol..
Old 03-03-2011, 01:39 PM   #6
Yep, 1/4" is .250" and 9/32 is .2812" so it's definatly 428, if your sprockets were about .187"-.200" then i'd say 420 chain
Old 03-03-2011, 02:33 PM   #7
sweet, thank you.. the page i was checking the information out on had me thinking i had a 520 chain.. stupid bad information..now im one small step closer to getting my quad back to running shape if i dont light it on fire out of frustration with my head light wiring..
Old 03-03-2011, 05:45 PM   #8
I used 520/O-ring on the Blastard because the blaster comes stock with 520 and I was so glad I could find countershaft sprockets to fit the china engine.
Old 03-03-2011, 09:49 PM   #9
Well you said 1/2" pitch, so it can't be 520, the first number in the chain size number is the pitch measured in 8ths, so 1/2" pitch=4/8ths, so it could be #40, 420 or 428, now #40 and 428 are basically the same pitch and width but i find the 428 to have heavier links and a higher tensile strength.
Old 03-03-2011, 10:17 PM   #10
well im ordering a did 428 chain, just need to figure out the length.. is a single link 2 rollers ?
Old 03-03-2011, 11:57 PM   #11
A link is a link, you need to count the outer and inner links, i believe the last DID 428 chain i bought for my beast came as a 130 link chain.
Old 03-04-2011, 12:01 AM   #12
well i counted 52 or 53 pairs of rollers, thought those where "links" so i just paid for a did 428 standard non oring 110 link chain.. so either way its long enough, i thought it might be long enough to make 2 full chains so i can have one in storage for when i need to replace it again
Old 03-04-2011, 07:01 AM   #13
Well since a pair is "2", then based on your roller count you should be about 104-106 links.
Old 05-09-2011, 06:16 PM   #14
johnwayne   johnwayne is offline
thought i should add that the 2010 limited edition beast has a 530 chain
