Old 02-22-2011, 07:43 PM   #1
Tracer   Tracer is offline
Brakes
My brakes stoped working changed master cylinder still nothing
Old 02-22-2011, 08:09 PM   #2
Jim   Jim is offline
Details.
"Be excellent to each other"
Old 02-22-2011, 08:22 PM   #3
Brakes
My dads brakes stoped working no brakes so I changed the master cyclinder and stil have no brakes I don't no what to do fluid comes out of the bleeder valves but no brakes
Old 02-22-2011, 08:24 PM   #4
jape   jape is offline
Well heck what a shame.
I wouldn't ride far then.
Old 02-22-2011, 08:33 PM   #5
Ha ha
Old 02-22-2011, 08:39 PM   #6
Jim   Jim is offline
Originally Posted by Jim
Details.
By details, I mean, please provide us with details. Your dads brakes stopped working on what? His car?
Obviously you don't mean his car, but we can't read your mind. Are you talking about the 300 Sumoto, or the atv from Sinclairs whatever it may be? Disc brakes? Drum brakes? Front? Rear? Is the fluid coming out when you attempt to use the brakes, or just when you're bleeding them? Are the brake shoes or pads moving? In good shape?
Details please. I'm not an expert, but we have a lot of knowledgeable people, however I don't think they can read minds either.
Old 02-22-2011, 08:52 PM   #7
Sorry guys it's on a 400cc disk brakes pads are I good shape brake fluid come out of the bleeder pad move in put not enough to stop the atv
Old 02-22-2011, 09:54 PM   #8
That's a good start.
May we have some background information? What do you mean when you say 400cc? Is it a China quad or a name brand? Please be as specific as you can.
Also, did the brakes work properly and then suddenly fail, or is this a new unit that has never worked? The more we know, the more likely that we are able to help you.
Old 02-22-2011, 10:20 PM   #9
Do you mean the fluid comes out of the bleeder valve OK when you replaced the cylinder and then re-bled the system? Or do you mean that the brakes bleed fluid at that point even if the valve is closed WHEN you apply the brakes?
And is this front AND rear or what?
Either way, if that valving is stuffed or not, are you saying you are getting some pressure through to the pads, then they are moving just a little but seizing in their slots?
I suggest you disassemble that part of the system as best you can, or get in there and try and clean it all up and get dust and grit and so on out to free up the pad movement. You need free moving pads. If they are locked up then the fluid will come out anywhere it can if you squeeze hard!
Sounds like the pads are seizing and you have blown any valve seals when trying to force it to work? It should take just a light pressure on the brake lever to actuate the disc in and out.
We will get you sorted if you give us more and more details. Then your dad will be amazed. Try and answer each question in order, If you don't understand a question, say so. Sometimes it is difficult to explain stuff in writing because we expect someone understands but usually they don't.!!!!
Just help us to help you by slowing down a bit and telling us, bit by bit, what we ask please.
Old 02-22-2011, 11:11 PM   #10
It is a rocket atv the brakes were working good then failed there is fluid coming out the bleeder screw when I open it and pump the leaver
Old 02-22-2011, 11:46 PM   #11
well unless I misunderstood, that is meant to happen, that valve opens so you can bleed the brake lines and get rid of air, which you have done?
So you know the line from lever to valve is OK at least, Time to check the next bit.
So o the clean up round the pads and checks on why the pads aren't moving. to see if they can move if you wiggle them. In other words if the pads are sticking or not. You need to know that because If the pads are locked solid because of grit or dust then the lines are probably OK but If the pads can move with a bit of help from you (not using the levers) you have to check back from there along the lines and maybe see if they are obstructed.
I need to know where the bleeder valve/screw is or I may be thinking this all wrong! Buit from what you say it is OK that far and it is from there to the pads it is not working?
Let us know how you go.
Old 02-23-2011, 08:37 AM   #12
waynev   waynev is offline
I'm confused by what you mean, if you open the bleed screw and pump the lever it will shoot out brake fluid, but this does nothing to bleed the brakes as air likes to sit at the top of the system, if i was having problems i'd remove the caliper, hold it above the master cylinder, place something inbetween the pads the same thickness as the rotor, then fill the master cylinder, pump the lever about 5 times then hold pressure on the lever, then you open the bleed screw to let the air out, you will feel the lever pull in as you bleed the air and fluid out, you may have to repeat this step several times til you get all the air out, also make sure you keep the master full when doing this.
Try this method first and if still you have no brakes then check for leaks in the lines, sometimes the rubber o-rings on the caliper pistons also go bad, looks for leaks there too.
Old 02-23-2011, 03:06 PM   #13
mizke   mizke is offline
when i got my quad since it was used, the rear caliper was seized and the master had some blown seals.. you can find complete rear brake kits on ebay for less then 50 shipped.. just find a rear brake system that the caliper looks exactly like ur current one and replace it
200cc beast replica,carsoli cdi,performance coil,fmf powercore 2,uni air filter,hour/tach meter,jetted mikuni carb,msr bars,moose racing grips,yz250f clutch perch,D.I.D chain
Old 02-23-2011, 09:32 PM   #14
bleeding brakes
the trouble with alot of the brake systems is that they loose their residual pressure and you can not bleed them because there is too much fluid required to get the air out of the brake calipher..
This is what works for me.....
push the brake pads all the way back to the housing... insert something inside the calipher to take up ALL the space.. ( or use C clamps to hold the pistons from moving)
unscrew the bleed screw at the housing and wait until brake fluid is leaking out of it ( DO NOT APPLY THE BRAKES ) LET THE GRAVITY CAUSE THE FLUID TO FLOW DOWN
once you have fluid leaking at the screw .. apply the brakes.. you should bleed the system the normal way.. you will see that it will bleed any air out of the system up to the calipher.... once bleed and no air is coming out of the bleed screw ... reinstall the calipher on the atv... ( with pads) then slowly re-bleed ( keep the fluid fill up) there should be no air in the calipher so it will apply the brakes and work ok..
I have done this to many brake setup.. it works with some patience..
ABIBABA ATV ETC
