Old 01-06-2011, 09:41 AM   #1
Cal25   Cal25 is offline
Think I broke my shock
Hibird 250 enduro, GY-2 variant.
Dropped my truck at the transmission shop for some repairs and took my bike in the back for the ride home. After a block or so, something did not fell right so I stopped and looked things over but did not see anything unusuall. Rode a few more blocks and new something was wrong. I found a place to pull over and give it a closer look. When i tried to stand the bike with the kick stand, it would not stand, like the kick stand was too long. Further investigating showed that the rear suspention was completely compressed. I tried placing a foot on the rear rim and pulling up on the rear rack but it would not budge.
Took over 2 hours on the smoothest backroads i could find to get home.
Has anyone heard of a shock doing this?
Could it be something other than the shock? Hard to believe easy riding on city streets could even get the rear suspention completely compressed. The shock mounts are intact.
I will try to do some dis assembly tonight as I was too sore to work on it last night LOL.
Old 01-06-2011, 10:30 AM   #2
Even if all the gas leaks out of a conventional shock, the spring should still support the weight. In any automotive suspension, the shock is there only to dampen the spring action.
My guess is that either the shock body is bent or the spring is broken.
Old 01-06-2011, 10:32 AM   #3
Another thought: does your swingarm have a link? Maybe the link came apart at the fulcrum.
Old 01-06-2011, 11:22 AM   #4
The bottom of the shock is on a linkage system. Looks ok at first glance.
The bottom 4 coils or so are completely compressed. Cant see any sign of breakage.
Old 01-06-2011, 12:03 PM   #5
I bet that you'll find the shock body to be jammed. It seems likely that the coils are compressed because the shock body won't retract.
It sounds like it's time for a new shock.
Old 01-06-2011, 12:52 PM   #6
Would have been easier if the shock would jammed in the fully extended position. Hard to tell what the extended length is. But "if it was easy, everyone would do it" I always say.
Old 01-06-2011, 01:02 PM   #7
Wild_Alaskan's Avatar
if the shock is the same as the gy-5 there are tons of aftermarket options for about $100. if its the same ill dig up some threads and links.
edit:
gy-5 had an 11.5 inch shock
Old 01-06-2011, 01:05 PM   #8
Jim   Jim is offline
My gy6 had a longer shock then the gy5, but I don't recall the lengths.
"Be excellent to each other"
Old 01-06-2011, 01:21 PM   #9
crap meant gy-5 :oops:
Old 01-06-2011, 02:22 PM   #10
katoranger's Avatar
Cal, I have a GY5 one.
Will send it to you if you think it will fit.
Allen
Old 01-06-2011, 03:14 PM   #11
I will see if the 11.5 measurement is close. That makes it easier to measure I think.
Katoranger, i might take you up on the offer as well as look at the options Wild_Alaskan comes up with.
Old 01-06-2011, 03:33 PM   #12
katoranger's Avatar
Let me know and I will get it off to TX.
Allen
Old 01-06-2011, 07:47 PM   #13
Got home this evening and the shock had relaxed a bit while the rear tire has been off the ground for 24 hours. Popped off the shock and swingarm move full motion quite easily. Measured the eye to eye and the measurement is a little over 11 inches. 11.5 would be about right if it would rebound all the way.
here is a pic. it is upside down in the pic.
Old 01-06-2011, 07:53 PM   #14
Interesting. I've not seen one jam up like that but I'd never put anything past a Chinabike.... :roll:
It's nice that Kato can help you out. He's helped me, and many of us in the past.
Good group here.
Old 01-07-2011, 12:18 AM   #15
heres another option, if you want ajustability and such but you will have to space it out and adapt it to a 10mm bolt vs the 12 mm stock on the frame.
http://cgi.ebay.com/ebaymotors/RACIN...Q5fAccessories
