New Parts
Well i just installed new performance CDI and new Mikuni 30mm carb runs much better now..pulls wheelies no problem just need some pointers on fine tuning carb it seems to wanna stall out unless i give it gas
Are you saying it doesn't idle very good? Does it get better if you add choke?, could be the idle is a bit lean, try turning your A/F screw out a 1/4 turn or so, if your more than 2 turns out then a bigger pilot jet is needed.
For reference, the 30mm carbs i've seen come with a 20 pilot and 100 main jet installed, most of the people with 200cc beasts on here have gone to a 110 main and 25 pilot with good results. |
yeah i didnt get much time to tinker with it before dark just ook it down the street and back im gonna mess around with it tomorrow
now i need some good performance shocks all the way around it and i will be good does any one know where i can get some other than giobikes.com
OK i am having problems getting bike to idle now. It will idle for about 30 seconds then it just gets so low it stalls out i have adjusted the air/ fuel mix it doesnt seem to help any. The only thing i havent done is adjust the needle.....PLEASE HELP...LOL!!!!!!!!
#6 | |
just so im right the a/f screw is on the bottom of the car correct???
#8 | |
ok im taking new carb back off to look at it a little better I will be posting pics here in about an hour
#10 |
and also how do i tell which length of pilot jet and main to buy??
#11 | |
Jets are cheap, but as mentioned before your new carb should have came with a 100 main and 20 pilot and i have suggested what other members are using which is the 110 main and 25 pilot, most of us have done all the upgrades though, cdi, mikuni carb, UNI air filter and some exhaust work. Does your carb say mikuni on it?. |
#12 |
new carb on the right
#13 |
Sorry the pics are so p00py
#14 |
New one with cover off
#15 |
I really need help... im not sure what type of jet to buy .I know i want a 110 main jet and 25 pilot . Would my best bet be to take the whole carb to the parts store and have them match them...i just tell them what size i want Right??
