12-08-2010, 07:13 PM | #1 |
06 Lifan 200GY $500 fixer upper
Just bought my 200GY5 ($500 ) and doing a preflight inspection found the rear sprocket was loose. Wondered if there was any write up about taking it apart. I'm sure I'll be ok once I put the wrenches too it but any education is helpful before I start. Just want to tighten it up right? Just have to fix that, do some headlight repair, repaint the plastic (PO painted it flat black), fix the floppy kickstart, and ....fix the throttle...excited son was twisting the throttle back further and further and HEY that shouldnt spin all the way around...broke the plastic that holds the throttle cable in place.
12-08-2010, 07:30 PM | #2 | |
Re: 06 Lifan 200GY $500 fixer upper
12-08-2010, 07:33 PM | #3 |
yellowxj,
Sprocket can get loose? I better check mine too. I don't have a check list or know enough to make one yet. |
12-08-2010, 08:21 PM | #4 |
Welcome. On the sprockets. It was well known for the studs that bolt to the sprocket to shear off. Also the rubber parts fail due to cheap china rubber.
The sprocket should be held on with a large c-clip. http://www.bikebandit.com/houseofmot...m2988#sch20077 Sprocket may have a small amount of play after installed. The parts are available from honda
12-08-2010, 09:17 PM | #5 |
THANKS. If I'm reading the rear wheel picture right the bolts that go thru the sprocket fit in to bushings in the rear hub so for the sprocket to have a little play is ok. Just means the bushings are a little worn? Cool. Hope to upgrading the sprocket soon any way...
Now Ive got to figure out the head light...bulbs missing and the connector is broken...headlight is broken on one side where it bolts to the mounting bracket/cowl...thinking about some LED driving lights for low beams and a small off road light for high...I can probably make it all fit...fabrication time... |
12-08-2010, 10:48 PM | #6 | |
A few of us have converted to H-4 base headlight bulbs...get one of those bases at the local salvage yard :wink: . Good luck with the fixes. Bill R |
12-09-2010, 08:55 AM | #7 |
Send me a PM. I may have some parts left that you can use. I have a 42T? rear sprocket. Got the whole rear wheel if you are interested. A few other pieces too. This is all from BillRs bike that I parted.
Allen
12-09-2010, 06:16 PM | #8 |
Thanks, got a lot checked out today..got the throttle fixed, adjusted the clutch, painted bits and pieces, took the battery out, added water, and put a hard charge on the battery...put it back on and POW...electric starter works now...then I put a 55w off road light on as a head light BUT...it was really dim at idle...when I revved the bike the light got brighter and brighter and POW...lights out...dont know if it was a old bulb (in an old light...its matching light had already blown)...put an LED tail light bulb in...works great but no running light...related to the head light? Nothing else went POW...son hopped on his Honda and we raced around the pastures for a bit...bike did great. (He just outgrew his china 50cc bike's...got a flawless honda 70 for $500 for him)
Thanks, for the parts offer...I'll be passing through the ATL day after x-mas...heading up to Blue Ridge for a wedding... [img] Uploaded with ImageShack.us[/img] |
12-09-2010, 08:03 PM | #9 |
You got a lot accomplished today; your bike looks good, XJ!
12-09-2010, 08:20 PM | #10 |
Looks good
12-10-2010, 11:41 AM | #11 |
You're bike looks really good. I'm diggin' the flat black.
I wonder if 55 watts is a little much for the headlight switch and dimmer. I had 18 watt bulbs in my Gio Beast atv, and I intend to swap them for something brighter, but I'll use a relay to protect the switch and wiring. What wattage was the stock bulb?
12-10-2010, 08:54 PM | #12 |
Dont know..it was missing..doubt if it was more than 55 watts though...I cant imagine the bike putting out enough to blow the bulb...regular running light (tail light) isnt working either...time to take it to the alien workshop...its probe time
12-10-2010, 11:31 PM | #13 | |
12-11-2010, 01:14 AM | #14 |
500.00!? 8O
Smokin deal! Wow!
12-11-2010, 09:02 AM | #15 |
It may have been AC voltage going to the bulb.
I will gone at Christmas, but if you are interested in parts let me know. I may be able to put them someplace for you. Allen
