Old 04-16-2007, 12:32 PM   #1
jeffhei   jeffhei is offline
Turn signal switch
I noticed that there was alot of play in the turn signal button. The small screw that holds the turn signal arm on the switch mechanism inside the left control came loose on me this weekend. The loose screw rolling around in the control was causing my horn to beep once in a while [weird]. I added a little locktite.
2006 Lifan LF200GY-5
Old 04-16-2007, 06:54 PM   #2
Jim   Jim is offline
So you got it all fixed?
There is so many little things in there, I am never taking mine apart again unless I have too, took hours to get back together.
Old 04-16-2007, 10:24 PM   #3
The screw that came loose was in a difficult spot. I was lucky enough to get it tightened before the locktite dried. So it is fixed for now.
