Old 10-27-2010, 01:19 PM   #1
Barnone   Barnone is offline
Barnone's Avatar
16 tooth front sprocket Qlink XF200/XP200 question
Is there sufficient chain length on a new 2009 Qlink XF200 to install the 16 tooth front sprocket?
Thanks
Old 10-27-2010, 01:22 PM   #2
As I recall I installed a 4 tooth smaller rear sprocket with the 16 tooth front sprocket and did not need to alter the chain.
I'd go that route if you want to gear your Q as high as practical.
I got my parts from JP Motorsports in San Diego.
I think you could add a tooth to the front and use the stock chain with no other changes, but I'm not sure.
Old 10-27-2010, 02:11 PM   #3
Barnone's Avatar
FastDoc,
Thanks. Rain is about over here so maybe I can get a ride in. Nasty weather came in last night.
Old 10-27-2010, 08:31 PM   #4
Bar, I installed a 16T in the front and 44T in the rear and had no trouble with the chain.
Old 10-27-2010, 10:37 PM   #5
I believe that was my combination.
Old 10-27-2010, 11:43 PM   #6
Barnone's Avatar
david,
I'm just planning on doing the 16 now or waiting until the chain wears enough to fit.
Thanks
Old 10-28-2010, 09:09 AM   #7
yvrGY200   yvrGY200 is offline
Me and 2 other guys with Konker KMS 200 ( Qlink XF200 ) all did ours the same week with the 16T front sprocket. There was enougth length in the stock chain. My bike was around 150miles on the odo. There was only a few hundred miles higher. They also changed out the main jet in the carb from 122.5 to 125 , pilot jet to 35 We notice the response improved.
2009 Konker KMS200,06 Lifan LF200 GY5 (SOLD). 08 Sachs Madass , Royal Enfield 500 Bullet , Royal Enfield Diesel, Chang Jiang CJ750, Honda GB500 , 2010 Buell XB12s CG
Old 10-30-2010, 04:04 PM   #8
Barnone's Avatar
Did the 16 tooth swap today and am not looking for a 6th gear anymore. Nice and might try the smaller rear after break in.
Old 10-30-2010, 08:27 PM   #9
Good to hear. I'd still go with the smaller rear now, it makes break in easier. Easier to stay under the RPM limit.
Old 10-30-2010, 10:02 PM   #10
Barnone's Avatar
FastDoc,
Good point.
