Old 09-17-2010, 01:50 AM   #1
Feral   Feral is offline
Hensim HS250DB
From my other thread, I think I am going to go with this used Hensim Hs250DB as seen here.
http://saskatchewan.kijiji.ca/c-cars...AdIdZ227644864
That being said, I was wondering if anyone could chime in on general quality. Where I would be able to get parts, and if anyone in Canada has registered a bike similiar to this.
Any info on this bike you might have would be greatly appreciated.
Old 09-17-2010, 02:12 AM   #2
It's a Honda clone for sure, but I can't tell if it's OHC or pushrod. If it's OHC, then it's likely a decent copy of an XR200. Does the bike have current registration with SGI? If so, it should be a no-brainer.
Generic parts like levers, handlebars, etc are available anywhere. Bike-specific parts like gas tanks should be easy to find on eBay and online China bike stores.
Can't speak to the quality, but I would hammer him on the price.
Old 09-17-2010, 07:38 AM   #3
I haven't been on much due to working crazy hours (and have to for the next month... Yuck!) so I'm not sure if this was posted in your other thread or not. One of our other members (vtr99) has the same bike I think and here is his thread/review on it http://chinariders.net/modules.php?n...800&highlight=
If you have read through the thread already please disregard this post. Hope it's a great bike for you if you buy it
Cheers,
Stew
Old 09-17-2010, 09:46 AM   #4
Unfortunately it is not registered with SGI, and yes I did read the review thread. Thats one of the reasons im seriously considering it. vtr99 gave it a pretty good review from what ive seen.
Old 09-17-2010, 03:24 PM   #5
katoranger's Avatar
Its OHC, I can see the big sprocket cover in the pic.
Old 09-17-2010, 04:53 PM   #6
is OHC good then? Not really sure of the advantage.
Old 09-17-2010, 04:54 PM   #7
Cal25   Cal25 is offline
if its OHC it should be a true 250.
Old 09-17-2010, 05:15 PM   #8
hmm interesting, I was reading elsewhere that they were actually 233ccs, maybe it is a pushrod then? Unfortunately information is really sparse on them aside from the review on here.
Old 09-17-2010, 07:39 PM   #9
katoranger's Avatar
OHC means that Honda parts will likely fit. The OHV engines would be harder to source parts for.
It is possible that is is actually a 233cc engine like the crf230.
Allen
Old 09-18-2010, 12:42 PM   #10
It is theoretically possible that it's a 200; you never know until you measure the bore and stroke, but I'd be more focused on how it runs and if it meets your needs. BTW, the engine my son and I built for his XR200R is OHC; they're strong and reliable units, as long as they're not the 1984/85 four valve models. Yours is a more desirable two valve.
The displacement might be stamped on the side of the engine, but even that's not a guarantee.
Can you get the VIN from the seller and ask questions at SGI? Might save you alot of hassle.
Old 09-20-2010, 12:21 AM   #11
Oengus   Oengus is offline
This may confuse some…it is a document for the California air resource board. It related the Hensim ATV’s with a 230 cc engine. The engine within it is a 167MM. It very likely that is the engine used on the street bike as well as the ATV…different gear ratios maybe.
http://www.arb.ca.gov/msprog/onroad/...08_193-230.pdf
Model:167FMM-N
Displacement: 236ml
Compression ratio: 9.2:1
Primary reduction: 3.333
Bore*Stroke: 67mm*66mm
Max.Net Power & Rotating Speed: 10.5kw/7000r/min
Rated Power & Rotating Speed: 9.5kw/7000r/min
Max.Torpue & Rotating Speed: 15.8N.m/5500r/min
Min.Fuel Consumption:≤367g/kw.h
Ldling Speed:1500r/min
Ignition:CDI
Starter: electric/kick starter
Lubrication: Pressure/splash
Transmission: 4 /5speed
http://www.lifan.com/en/product_list...id=8608&id=887
Its likely that Lifan engine on the Hensim.
Old 09-20-2010, 01:21 AM   #12
It looks like the same engine used on the GioX31 dirt bikes?
