04-11-2007, 07:02 PM | #1 |
Fuel Grade
Hi everyone,
As most of you already know, I burned a valve on my Zongshen sierra not to long ago. It happened while crossing a long bridge at 65 mph (WOT) on a very hot day. (mid 80s) I just got back from the dealer who if fixing it under warranty and found out that the parts are expected next week. The deal said that Zongshen wanted to know what grade of gas I have been using. And to pass on to me that I should only use low octane fuel. Apparently the higher the octane the slower the burn thus reducing knock in high compression engines. However the Zongshen has a low compression engine and the fuel is still burning when the exhaust valve opens. causing power loss, engine over heating and valve damage. Who woulda thunk it? |
04-11-2007, 07:14 PM | #2 |
What are they meaning by lower octane? 89, 87, or as low as 86?
2009 XR650L Big Red Pig Tusk bar risers 2007 X-Moto(Jetmoto) GY250 --mods--- 15/40 sprockets UNI Pod Filter 2007 Shineray TMS 200XYi--Betsy Betsy Mods:______________________ Acerbis DHH headlight FMF Powercore pipe Uni Pod Filter |
04-11-2007, 07:22 PM | #3 |
They said run 86 in it.
The octane rating listed in the manual is the European/Asian number and that it is higher than the US system. 86 here equals 92 every where else. :o I am tempted to say that our bikes are happier with the cheap stuff but 86 octane isn't so cheap any more :( |
04-11-2007, 07:28 PM | #4 |
We're at 3.25 to 3.30 a gallon here in CA.
04-11-2007, 07:30 PM | #5 |
i've been running 93 in mine for a while now and nothing has happened so far. i have been thinking about switching down to the 87 stuff though.
Roketa DB-07a HID Headlight |
04-11-2007, 07:50 PM | #6 |
We were told to run 91+ or you would foul up your plugs and your bike wouldn't like it.
More info would be nice |
04-11-2007, 08:12 PM | #7 | |
There are three different ways to figure octane ratings...Read This> http://www.geocities.com/motorcity/l...0/octane1.html Bruce
04-11-2007, 08:15 PM | #8 | |
Re: Fuel Grade
its the FASTER more complete burn of premium that REDUCES knock. same as in a hi-performance auto. and same as in a high performance auto, the SSLOWER burn of lower octane causes knock have you fiddled with your carb settings or jets? could be slobbering rich and or timing might be a bit off which could also cause unburned fuel passin the valve
The Journey -IS- The Destination |
04-11-2007, 08:31 PM | #9 | |
What about the Lifan engines? I can't remember what the manual says (If I even knew where the manual was). The site I bought the bike from (HooperImports), has a scan of the EPA sticker and it says "RESEARCH OCTANE NO. 89 MIN" (That should be a RON of 89). Now, what that 89 means is totally up to speculation. While one would hope that the Chinese understood our rating system over here, one would also assume that there is a high chance that they might have gotten it wrong.
From Wikipedia: http://en.wikipedia.org/wiki/Octane_rating Quote:
1. The octane of RON89 on the sticker is actually a true RON89 rating and you should be able to use fuel 4 to 5 points lower. or... 2. The Chinese actually took the time to convert the octane rating to the (R+M)/2 standard that we have here in the US but didn't know enough to say that on the label. I started out running 87 and found that I got a little pinging going up hills under load so I tried 89. It seemed to eliminate the pinging but, to tell you the truth, its a little hard discerning pinging form any other noise and vibration so I'm not really sure. I plan to go back to 87 this season unless I think I hear pinging again. Oh, and for anybody who's not all that farmiliar with Octane, definately read that Wiki. But in short there's one thing that is important that many people seem to not understand: Running a higher octane fuel than necessary for the compression of the engine is a complete waste of money and does not offer any performance gains. From what I understand, since higher octane fuel has less energy, it will actually produce less power than a lower octane fuel. |
04-11-2007, 08:54 PM | #10 | |
BTW what is the actuall compression and timing of our engines? i have the over head cam engine.
04-11-2007, 09:01 PM | #11 |
I second with FMY!.......all backwards
high octane=slower burn I agree......these bikes only need 87
<div>Steve 2006 Roketa DB-07A/RSX-200E 2008 Roketa 250 Scooter 2019 Brozz 250 |
04-11-2007, 09:10 PM | #12 | |
04-11-2007, 09:34 PM | #13 | |
Edit - Found the link: http://www.hooperimports.com/product.asp?pf_id=E2005M |
04-11-2007, 09:44 PM | #14 | |
Re: Fuel Grade
04-12-2007, 12:32 AM | #15 |
I've been using premium, not sure what it is octane wise.... The guy I got it from said I might aswell use the premium when I bought mine, but then he told my dad and his friends when they bought theirs they could use whatever gas... So I don't know what he really recomends...
So far no problems with the premium, but I dont have too many k's yet... |
