04-10-2007, 04:40 PM | #1 |
Spark plug selection
I found this to be very interesting. Has anyone chosen a plug other than what came with the bike or that was an exact cross reference plug?
http://dirtbike.off-road.com/dirtbik....jsp?id=332655
04-10-2007, 04:48 PM | #2 |
Hey, thanks! Good info. Another one to add to the tech pages?
~Pauli~ Former 2006 Viva VX200SX owner |
04-10-2007, 05:02 PM | #3 |
i put a ngk d8ea plug in mine
06 american lifan 200 gy-5 |
04-10-2007, 07:27 PM | #4 |
I just put a NGKDR8EA in mine after running the stock plug for 3000 miles. Wow, what a difference. The bike is much more peppier, doesnt bog down when I want to pop wheelies, especially when it gets hot. I noticed my engine running a lot smoother at higher rpms also.
04-11-2007, 09:18 AM | #5 |
Does anyone know the difference between a DPR8EA-9 plug? I for some reason have two of those in the garage and I don't have a clue as to what bike they may have gone with over the years.
Jason
04-11-2007, 10:28 AM | #6 |
+1 for the NGK D8EA. I just installed one in my Viva a few days ago. With the oil change yesterday the bike runs completely different. Money well spent!
2013 Jeep Wrangler Sahara MOAB 2005 BMW E53 X5 2011 Schutt Industries LTT-HC LQG trailer 2017 Coleman CT200U 1978 Yamaha SR500E 1979 Yamaha XS650 Special II |
04-11-2007, 11:22 AM | #7 |
These 200cc engines are set up for The NGK D8EA, D7EA, D6EA spark plugs. Other numbered plugs can cause problems read all 5 pages: http://www.ngksparkplugs.com/techinf...000&country=US
NGK Spark plugs heat ranges go like this...The small the first number the Hotter the plug, the larger the number the colder the plug. So a D6EA is a Hotter plug than a D8EA. I hope that this helps. Bruce
04-11-2007, 12:01 PM | #8 |
Any one tried a Bosch Platinum or Splitfire plug.I use the Bosch platinum plugs in my Toyota Celica and like them.
04-11-2007, 04:01 PM | #9 | |
04-11-2007, 08:02 PM | #10 |
Ok here is an NGK PDF file that explains the letters & numbers on their spark plugs, as all plugs are for certain applications that is the incorrect plug for these bikes, I know that A. Lifan says to use a D7/D8 in the owners manual...Twice.
http://www.ngksparkplugs.com/techinf...tnumberkey.pdf Bruce
04-12-2007, 09:36 AM | #11 |
Apart from the P for projected insulator I don't see anything of significance that would be an issue. Maybe I'm missing something. Anybody?
Jason
04-12-2007, 04:24 PM | #12 |
Fatboy,
According to the site Bruce provided... P is for projected insulator. R is for resistor type. And that plugs runs on the cold end of the spectrum. Does the reach and insulator length match the d8ea or dr8ea? if you know that then maybe you would have your answer. Im operating on the dr8ea, per the tech section here on spark plug compatiblity. NET
2006 HIBIRD QH200-st atv, 2005 Kinroad 200GY-01, 2006 Roketa DB-05, 1980 Kawasaki KZ440 LTD |
04-12-2007, 04:34 PM | #13 |
maf,
I tried to cross reference to get to a bosch, splitfire or platinum.. but couldnt.. yet.. I do understand they are developing some plugs for bikes though.. Maybe sometime this year according to their site.. NET
04-12-2007, 04:45 PM | #14 | |
Anyway, I guess it should be about the same since it is still an 8 heat rating. The 9 references the gap (.036")
04-12-2007, 04:48 PM | #15 |
splitfire is just hype. electricity will alwas take the path of least resistance.
