Old 04-08-2007, 09:20 AM   #1
cycleway4   cycleway4 is offline
speedo drive hub seal...and speedo cable
Hi...I've thought of this a few times when reading about speedo issues, but keep forgetting to post about it.....Have other Roketa owners, and maybe other brands as well, noticed the speedo drive hub seal as supplied with the bike, does not exactly amount to anything? Its ID measurement is 42mm,....[OD is 50 mm]....but the wheel hub surface its supposed to seal/ride against is 40 mm. That of course is not going to keep nothing out of the speedo drive internals.....water, dirt, dust, mud, etc.....
Anyway, I was able to locate a 40x50x8 seal locally and that nicely fixes that problem!
As far as the cable,...the stock cable at just under 40" is a bit short and stressed as supplied and routed......I was able to use a cable meant for a Kawasaki 350 Bighorn [42"] and improve that situation, too....
***note that this is not a direct fit replacement as one knurled nut has to be slightly enlarged and threaded to fit,.....but it was no big deal...works/fits great!
<div>Steve
2006 Roketa DB-07A/RSX-200E
2008 Roketa 250 Scooter
2019 Brozz 250
Old 04-08-2007, 10:02 AM   #2
FMYStreetRacer   FMYStreetRacer is offline
please post pics, i'm very interested in this.
Roketa DB-07a
HID Headlight
Old 04-08-2007, 11:11 AM   #3
red2003   red2003 is offline
My 06 DB07a sealed up fine. Nice and tight. Maybe you got an oddball seal???
Old 04-08-2007, 11:51 AM   #4
Hi FMY....I am away from home-base for a few days.........will try and get some pics later in the week...........
Because of the odd angle of the speedo cable coming from the drive[at least in my opinion], and the fact that the seal is not available seperately from Roketa, I did order a replacement speedo drive unit to see if mine was just all wrong....new one was the same way, so sourced a seal locally.
<div>Steve
2019 Brozz 250
Old 04-08-2007, 12:46 PM   #5
yeah man let me know how it turns out. i was just going to order a lifan setup but now i've been toying with getting rid of the cable all together and going with a electronic dash.
Roketa DB-07a
HID Headlight
