08-11-2010, 04:43 PM | #1 |
what is this
can some one please tell me what this 3rd screw is
its the top on between the 2 bowl screw holes.. its got a very small top on it, and the screw has a spring.. look at the bottem most jet it goes main, pilot, and then ? i have no idea what it is... |
08-11-2010, 05:34 PM | #2 |
That is your air/fuel screw, you adjust this to change your mixture at idle, normal is about 1-2 turns out from fully closed, anything over 2-1/2 turns out means you need a bigger pilot jet, less than 3/4 of a turn out and you could go down a pilot jet size.
Normally you would adjust it for a good idle with no hesitation off idle, screwing it in will be leaner and screwing it out will be richer. |
08-11-2010, 05:38 PM | #3 |
u sure cuz the little adjustment screw off to the left side of the carb that is just barely sticking out is the idle adjustment.. i turn that screw and the idle picks up or dies off.
08-11-2010, 05:43 PM | #4 |
Yep, the idle screw on the side controls the rpm of the engine as it opens and closes the slide as you screw it in or out, the A/F screw adjusts the mixture, lean / rich for idle.
08-11-2010, 05:51 PM | #5 |
i see ok thanks
