08-09-2010, 06:01 AM | #1 |
gio beast honda & yamaha part numbers
so thought a list of honda part numbers that can be used to replace broken items on the beast as well as other atv's like mine would be mighty handy to have and to share..
these are what i have now, thanks to anthonyfa18 for the oil parts part numbers THROTTLE CABLE LENGTH 46" top to bend MIKUNI JETS (the jets that fit the mikuni performance carb) VM28/486 Series Pilot Jet Fits RS, and HSR Mikuni Carbs Mikuni N100.604 Series Main Jet spark plug ngk iridium xi dpr8eix-9 16950-MEN-731 PETCOCK ASSY crf450r honda ATC200 A (81) clutch: 22201-gf6-000 oil filter: 15421-107-000 oil filter spring: 15426-107-000 bolt seal: 91303-107-000 filter bolt: 12361-383-000 oem honda renthal bars CRF250X AC/A (07) 53100-MEN-670 YAMAHA part numbers swingarm bushing 307-22123-0 if any one has any else, please pm me the part name and number and i will add it this list as well as give you creidt for your contribution..dont want part numbers scattered through the thread.. |
08-09-2010, 10:53 PM | #2 |
lol i have a lot of honda parts on my beast because i work at acura lol
2008 gio beast 200cc mod list YTX14-BS battery mod,gy6 carb 250cc,custom intake,125cc cf dirtbike muffler,MPR filter/intake,performance cdi,ngk iridium xi dpr8eix-9,performance coil pack and wire, pro taper handle bar, Gio air shocks, yam swing arm bus |
08-10-2010, 12:32 AM | #3 |
i was just super stoked to find out the clutch part number.. thats been something ive been stressing out about big time.. cuz sooner or later the clutch is going to go
you know anthony im going to hate you after winter with that 250 going in.. dude if i have to i will extend my swingarm and then trade you so you can have a extended one.. then i will jsut extend the one you send me for myself.. also took a look at the steering system and figured out a way to get a little more turning ability out of the quad..cuz its going to need it with the swingarm extension.. extending the swing arm reduces turning radius..also cant wait for the extended control arms.. but thats in my build thread.. this one is for oem honda parts that will work on the gio beast and other quads built the same way.. so if you guys come across any part numbers that can be used on the beast and other quads that at beast clones like the kayak kn200s.. pm me and they will be added at the top |
08-10-2010, 10:38 PM | #4 | |
"025262 tucker rocky se hbar xr50 jet bk py"
08-11-2010, 12:04 AM | #5 |
im going renthal bars, and the handle bars are not what reduce turning angle.. look down the stem to where the tie rods attach at the base of the steering stem.. you will see the problem when you turn full lock to lock..
08-24-2010, 11:05 PM | #6 |
the should be a Sticky
and also her is the oem honda renthal bars 53100-MEN-670 from CRF250X AC/A (07) this will also work on a beast
10-14-2010, 02:12 PM | #7 | |
could a mod or admin please sticky this
200cc beast replica,carsoli cdi,performance coil,fmf powercore 2,uni air filter,hour/tach meter,jetted mikuni carb,msr bars,moose racing grips,yz250f clutch perch,D.I.D chain |
01-08-2011, 06:02 PM | #8 |
bump for a sticky
