Old 07-20-2010, 10:45 PM   #1
pooty6699   pooty6699 is offline
X31 neutral issues
Alright so I have adjusted my clutch and im getting same prob. When bike is cold and in gear I can easily get into neutral however when it is hot it is very hard to get into. Any suggestions
Old 07-20-2010, 11:00 PM   #2
Does the idle increase as the bike warms up? They don't like to go in gear if the engine is racing. Lots of these chinese machines come with the idle set very high.
Old 07-20-2010, 11:15 PM   #3
It idles normal, in fact i was about to adjust it cause it would occasionally stall. I just put a new mikuni in it. Although the clutch is fully pressed
Old 07-21-2010, 01:53 AM   #4
Have you tried synthetic oil?
Old 07-21-2010, 05:53 PM   #5
No I haven't I've been told not use synthetic in a brand new engine, no clue why but im starting to think I may throw it in.
Old 07-22-2010, 02:13 AM   #6
AZ200cc   AZ200cc is offline
After break in You can run synthetic, What oil is in it now?
Old 07-22-2010, 07:51 PM   #7
10/40 atv oil for wet clutch virtually the same as 10/40 motorcycle oil
Old 07-22-2010, 08:21 PM   #8
FosterVS   FosterVS is offline
Had mine for about a month, been using synthetic since day 1, also have trouble finding neutral as well.
Old 08-01-2010, 01:32 AM   #9
FINDING NUETRAL
I think the main thing is to have the idle as low as possible.. and then make sure you adjust the clutch right up to make sure when you depress the clutch ( to allow you to put it into gear) you have full travel.. no free play allowed.. and the better oil is better for it as well..
Old 08-01-2010, 12:17 PM   #10
I believe that it's hard on the clutch to have no free play; I shoot for 1/8" to 1/4" at the perch per the manual.
Old 08-01-2010, 05:45 PM   #11
brentn   brentn is offline
I find with my girlfriends x31 it is very hard to find nuetral. You MUST have the bike rolling usually to get it to go. I usually rock it back and forth about a foot while lightly pressing up and she'll pop in.
Old 08-06-2010, 02:48 AM   #12
There is no free play in my clutch, I fine adjusted it and with 1/8 " free play, in gear with clutch engaged it will take off.
Old 08-06-2010, 02:57 AM   #13
mizke   mizke is offline
i think that is normal to have to have the bike/quad moving to get it into some gears.. i can go out and depress my clutch, click into reverse, then back to n, and then into 1st but to get into 2nd or higher at a stand still i have to rock it a little..
i would not worry about unless its doing this while rolling..
also as said in another thread in the section... castrol 4 stroke oil.. is good stuff
Old 08-27-2010, 12:58 AM   #14
clutch adjustment
take the lever off of the clutch rod on the motor... move it forward to allow you to move the clutch so you get extra travel.. you will see when you adjust the clutch cable at the motor as much as you can... and then adjust the hand clutch lever more.. you will be able to put the trans in gear with out the bike moving forward... this is the way the clutch has to be.. when clutch is applied... and gear selection is made... THE BIKE SHOULD NOT MOVE FORWARD... this is a must.. so adjust the clutch as needed.. there is nothing saying about free play.. they always say what I said in large letters.. this means the clutch is working as it should... you have to have so much travel to full release the clutch from the motor.. I do this to all my bikes and atv.s ( T3 ) and all works well.. excellent smooth shifting
Old 08-29-2010, 01:08 PM   #15
Just dumped the synthetic, and installed Rotella 15W40 ( couldn't find Rotella 15W40 synthetic anywhere... grr...)
I swear neutral is easier to find now!
