07-04-2010, 08:12 PM | #1 |
Lifan Not charging at higher rpms.
This Lifan 140cc is installed in my 2008 Lifan lf110gy3 clone.
It has a lighting coil in it and the factory bikes wiring and battery is intact. (New battery as of March of this year) This is the Problem I am having. The engine doesnt charge at cruising rpms. Last night was the first night I Took it out after the running issue I had forever. The lights were all good to go but 10 minutes into the ride the lights got dimmer and dimmer. But every time I Stopped at a light the lights would perk back up and be bright. I know the bike is charging at idle but I am not sure why it is not doing it at speed. Everything is tightend down and nothing looks out of place with the wiring. Any Ideas? |
07-05-2010, 05:37 AM | #2 | |
Re: Lifan Not charging at higher rpms.
07-05-2010, 02:00 PM | #3 |
It could be you are using the wrong flywheel and stator combo as some are 8 ploe or 6 pole. It could also be you have a bad voltage rectifier or it is simply wired wrong for your new set-up.
07-06-2010, 06:09 AM | #4 | |
07-07-2010, 11:59 PM | #5 |
my bike was also doing that
maybe something burnt in the wiring harness.I had to go through to find my problem from putting it together and hooking battery up wrong,live and learn
