Old 06-19-2010, 07:09 PM   #1
imagineer   imagineer is offline
RoketaPartsOnline.com
Our Roketa 200cc Enduro is running pooorly unless we keep the choke on. Sonme investigating turned up the rubber intake manifold has dry rotted and has a bunch of cracks in it. I suspect this might have been the problem, letting in too much air.
I found the correct part at RoketaPartsOnline.com for under $12. Has anyone out there bought from this company? If so, how are they to deal with.
I'm always leary about handing over CC information to an new retailer.
Old 06-19-2010, 08:41 PM   #2
Buzzkill   Buzzkill is offline
I hear Roketa is having problems right now, I have ordered from this site and always recieved what I ordered http://www.motopartsmax.com/index.ph...roducts_id/753
Old 06-20-2010, 01:47 AM   #3
I am not familiar with the vendor you mentioned; however, this vendor is using a different telephone number than the one used by Roketa.com.
Old 06-21-2010, 10:50 AM   #4
FWIW, I was right. The manifold was leaking, causing the bike to run too lean.
After cleaning the cracked intake manifold with carb cleaner and letting it dry. I coated the entire thing with high temp RTV gasket sealer. Wearing disposable gloves, I 'worked' the sealer into all the cracks, making sure to fill them. I added an extra layer of sealer along the suspect crack that was leaking air and let it sit overnight to cure.
Yesterday, I reassembled the bike and it runs great. After warmup, the bike can sit running at idle with no choke. Performance when riding is improved too.
I know the sealer on the manifold is a temporary fix, but it buys me some more time to look for the replacement part.
Old 06-21-2010, 11:06 AM   #5
Cal25   Cal25 is offline
I am surprised we did not pass that tip to you on your original post. It is a ggod way to temporarily fix a cracked intake.
Dont forget to think about the other brands. Most of these bikes are built from the same parts. If it looks the same, chances are it is the same.
Old 06-21-2010, 11:19 AM   #6
As a restorer of old bikes I've seen the sealer trick done many times and it's actually a permenant fix. Looks awful but works well.
Old 06-21-2010, 11:35 AM   #7
dsrt4   dsrt4 is offline
The rtv won't last very long if seeps any fuel at rest. If it does fail grab a tire patch kit and cut strips to fit over the holes. Rubber cement it on the boot and hose clamp it
Old 06-21-2010, 11:05 PM   #8
HotelRed   HotelRed is offline
I had ordered a fender from Roketa.com last month. When I heard about the legal problems I canceled the order. There were no answers to my calls & emails. They finally refunded my money after over a month. They may be back into it now but you should check with them by phone first.
I had the same problem with my manifold. I found one at another site but it did not have the exact angle so the air box would not go back on. I just put a UNI filter on it but it would be nice to have an air box.
Good luck with yours & keep us posted with your final result. Inquireing minds want to know.
John
