Old 06-01-2010, 07:35 PM   #1
mazotto   mazotto is offline
Full Throttle Engine Sputter on Roketa
Roketa DB-07 owner with Engine sputter issue. Bike idles great and runs great at half throttle in all gears. If open the throttle from half to a quick full in any gear (like leaving a stop light) the bike sputters and hesitates. :( . Never did it before. Any feedback would be great
thanks
Old 06-01-2010, 11:46 PM   #2
Re: Full Throttle Engine Sputter on Roketa
thanks
If you have not had this problem before, you might be developing a bad CDI unit. I encourage you to get a replacement CDI unit; it only costs about $15. Even if the CDI unit is not bad, you will have a replacement handy, and the spare CDI unit is a great aid in troubleshooting electrical problems.
Old 06-02-2010, 03:11 AM   #3
Wild_Alaskan's Avatar
your main jet is probably partially clogged in your carb, Clean it out and i bet it will run great again.
Old 06-02-2010, 04:27 AM   #4
Reveeen   Reveeen is offline
valve adjustment?
Old 06-03-2010, 02:29 PM   #5
Thanks for the feedback. I am having troubles locating a CDI for my Roketa DB-07. None of the ones on E-bay match the correct 6-pin orientation as the one on my Roketa. If anyone has part info that would be great. I did find one for $109 that was a exact match but i was looking for something that was a little cheaper.
Old 06-03-2010, 03:19 PM   #6
You should be able to get your CDI unit from Roketa. See if part #7, in the following parts diagram, is the correct unit.
http://www.roketa.com/product/parts_...SSEMBLY%282%29
Old 06-03-2010, 07:45 PM   #7
That's the CDI and after many web searches I found it in the link below. My brother who lives in another city and also owns a Roketa gave me his CDI to validate the problem. Regardless I ordered a new CDI today. I will keep you posted if this solves the problem
http://www.motopartsmax.com/index.ph...2/cPath/117_14
Old 06-03-2010, 09:39 PM   #8
alkamp   alkamp is offline
Just to give you something else to look for....I was having the same problem with my Shine, turned out to be a bad electrical connection in the harness.
http://www.chinariders.net/modules.p...021&highlight=
Old 06-03-2010, 09:41 PM   #9
HotelRed   HotelRed is offline
Good luck ordering from Roketa. They have my money for a month & no part. No answer to emails & phone calls. I'd cancel the order if I could get hold of them. I think I will just protest the credit card charge. That may get their attention.
End of rant. Thanks for you attention & sympathy & sorry for the interruption.
John
Old 06-03-2010, 10:47 PM   #10
John
I'm sorry to hear that, John. Roketa has been indicted for the illegal importation of ATVs. If you do a web search, you can find all the information about it. If I were you, I would protest the credit card charge, and try to get my money back.
Old 06-07-2010, 02:32 PM   #11
Once again this forum has been a valuable place for information. Replaced my CDI with a new one and the bike runs great. Thanks again all for the timely feeback and happy ridding trails to you.
Old 06-07-2010, 03:35 PM   #12
That's wonderful! Thank you for letting us know about your success. If you have not done so, I suggest you also purchase an extra CDI unit. Besides having a spare handy if you need one, the extra CDI unit is a great aid for troubleshooting electrical problems.
