Old 05-31-2010, 02:50 PM   #1
MX175 Barn Find
My son and I picked up a '78 MX175 barn find (pics later), and we have a question about oil injectors.
The bike hasn't run yet, so we're not into investing any cash at this time. The most we're springing for is oil, fuel and maybe a Chinese air filter, K&N style. On this model, the oil injector is located behind a cover on the right side of the engine. The pump drives off of a worm gear that is directly connected to the crankshaft. Oil flows out of the tank, into the injector and then an appropriate amount is pumped to the carb, based on throttle input.
The problem is that the entire pump assembly has been wet for a number of years, and it is completely rusted. We took the pump apart, and the gasket has disintegrated and a large spring inside is soon to follow.
We'd like to run without the injector and use premix. As far as I can tell, if we remove the pump and hoses, remove the oil tank, plug the port on the carb that was the oil delivery point, remove the pump cable and run around 40:1 premix, the bike should live. Any thoughts?
Old 05-31-2010, 06:36 PM   #2
fishman10's Avatar
premix
All would work, I might start with 32/1 mix and see how it reacts, yamaha always ran their injector units heavier than needed , probably to be on the safe side. My 1980 mx smoked alot with the stock injector setup.
2015 zongshen rx3,,(Sold),,,2016 bashan storm,,2005 Harley ultra classic.
Old 05-31-2010, 07:26 PM   #3
VinceDrake   VinceDrake is offline
Something I know something about! Yay!
I had Yamaha Rd series bikes, and did exactly that on all of them-- But yes a 32:1 is a better mix, especially for a barn find...
That being said, the RD350's the oil injector pump also acted as a crank seal... So the Injector housing had to stay in place-- Usually gutted and siliconed up, to keep the vac leaks away...
--Vince
"Sometimes it is better to say nothing, and let people think you're an idiot, than to open your mouth and prove it."
Old 06-01-2010, 12:42 AM   #4
Thanks for the input guys. I recently got rid of a PE175 that required premix, and the manual called for 20:1; it killed mosquitoes for miles. I tried 32:1 and then 40:1 before it was tolerable. I still have a full jerry can of 40:1, so I figured I'd try it.
If you guys think that 32:1 would be safer, I'll dump some more oil in.
BTW, the worm gear that drives the pump seems to have a seal, but we'll check more closely before we fire it up.
Old 06-01-2010, 02:52 AM   #5
AZ200cc   AZ200cc is offline
40:1 seems like it would be fine, Modern oils are better than the oil time stuff. But I am not an expert on 2 smokes.
Old 06-01-2010, 08:28 AM   #6
suprf1y   suprf1y is offline
That's exactly what I was going to say. Modern oils are so good.
I recently found a quality 2 stroke oil that can't be beat for value. Castrol Grand prix 2 stroke, It's for competition bikes, and $4/liter at Partsource.
I'll bought it for my KDX, but probably try it in the RM when my supply of castor oil runs out.
Old 06-01-2010, 10:10 AM   #7
Cal25   Cal25 is offline
My brother had a 1975 enduro 100 that he bought new. I dont remember the details but he did have an injectiom pump go bad. I remember the Yamaha mechanic say it was very very rare for that to happen. He just ran pre-mix in the bike from that point forward. Its a little more trouble for a bike ridden on the street, but for trail riding it is no problem using pre-mix.
Old 06-01-2010, 01:35 PM   #8
Reveeen   Reveeen is offline
Pre-mix is denser than plain old gasoline. What this means to you is: it is very likely you will have to increase the size of the main jet in the carb, otherwise in WOT (wide open throttle) situations it will run leaner than intended.
SO: WATCH THE PLUG!
Old 06-02-2010, 01:12 AM   #9
Thanks for the additional comments, guys. 8)
I'll be watching the plug closely. I figured that there might be a jet difference because the oil was injected at the carb exit, meaning only raw fuel flowed through the bowl and jets.
Old 06-02-2010, 01:20 AM   #10
Jim   Jim is offline
I'm sorry but I think it's time to demand pictures :wink:
"Be excellent to each other"
Old 06-02-2010, 01:56 AM   #11
Of course you're right Jim.
The seat needs foam and a cover, but at least the base is plastic. One side cover is missing, but I would struggle to even care about that.
There's a little dent in the tank, but it's not bad.
Here's the nasty oil pump after we sprayed Castrol Super Clean on it. It actually freed up a little, but I don't trust it.
We've got some work to do to free up the brakes and clutch lever. Maybe it'll even start this weekend.
Old 06-02-2010, 01:59 AM   #12
Jim   Jim is offline
Looks good, good luck with it this weekend
Old 06-02-2010, 02:39 AM   #13
Maybe a good soak in some Seafoam? Lubes and cleans....Never tried before but could be a cure.
Old 06-07-2010, 02:36 AM   #14
It lives!
We let the tank soak for a week with some rust and scale remover, and I added a handful of stainless screws to act as an abrasive; it did a remarkable job of removing the rust. The original filter and reserve assembly is shot, so we'll just have to keep an eye on the fuel level. An inline filter is cheaper.
I actually had a new spark plug that was exactly the right type. This is gettin' scary.
I cleaned the carb and did a hillbilly mod on the air cleaner, which means I used TurboT's old Beast air cleaner and some ABS pipe. It fits well enough.
I swapped the broken front brake cable for an old XR cable I had laying around. The housing was too short and the cable was too long, so I repositioned the brake arm on the drum until it worked. It grabs hard. The next order of business will be to free up the rear brake; it's rusted solid right now.
I took the seat cover and foam off of an old XR200 seat pan and cobbled it onto the MX175 pan. After a little more trimming, it might even be presentable.
I didn't have another 428 chain that was long enough, so after son of Weldangrind wire brushed the original chain, it got a bath in solvent. It was then blown off with the compressor and given a good coat of Maxima Chain Wax. It seems happy enough.
The pretzled handlebars were replaced with donor XR200 bars. It looks like somebody had a horrible incident with the original bars. 8O
On with the show. Here's the second start-up. I didn't have the camera ready the first time. It starts really easily, and kills mosquitoes for blocks.
Here's son of Weldangrind on the maiden voyage. He's taking it easy, because the clutch doesn't work yet, it only has a front brake, and we had to push start it.
I think I've since figured out the clutch. After the rear brake is functional, we've got a fun little buddy bike for virtually nothing.
Old 06-07-2010, 02:45 AM   #15
Jim   Jim is offline
Cool, glad to see you've got it going
