05-17-2010, 11:45 AM | #1 |
New project. 1987 Xr200 trade went through.
Well, two years ago I stopped at a garage sale. Lady had an xr200 in a shed in pieces. I asked about it. She wanted too much at the time. In another shed she had some other xrs that had not run in years. She wanted to get them running. I left my number and never heard back until about a month ago.
Worked out a trade. I got the other bikes running in trade for this bike. 1987 Xr200. Looks like the cam chain broke and it snap a valve. Engine is needs alot. I believe my OHV lifan will fit in this frame.
05-17-2010, 12:40 PM | #2 |
That project looks ambitious! The motor swap seems like the best way to go. Hopefully other Lifanoid parts will swap too. I picture a lot of time on eBay in your future!
Happy to serve. |
05-17-2010, 01:53 PM | #3 |
All I can see that is really missing is the rear brake pedal and rod. It may be still in the shed that it was in. I am going to go back and look.
The plastic is okay. I am going to paint it. The tank I think I can stripped the paint off and back to the origianl color. Otherwise I think just alittle wiring and some miscellaneous bolts. Seat is not too bad. Also needs a front tire to start, but I have one in the shed. The rear is a 17" so I will need to buy one of those. A former member had pretty much this same bike and the same lifan engine and did the swap. Allen
05-17-2010, 03:46 PM | #4 |
The '87 is a good choice; Honda went back to the two valve head (meaning that the Lifan should drop right in) and the seat is a modern type that climbs the tank.
I think I have a spare brake pedal for our '83 that is likely the same. It's a bit bent, but let me know if you need it.
05-17-2010, 05:12 PM | #5 |
I will need the pedal and rod if you got it. Little bent is fine with me.
No hurry, I am going to do this one right. Starting with painting the frame. I am sure I will find other missing pieces along the way. Overall its not too bad and Like WG said. No custom mounts needed for this one. Probably need help with wiring. Also going to use the xr carb since I can't find my lifan one. Rear wheel I believe need bearings. Allen
05-17-2010, 09:06 PM | #6 |
Give me some time to dig through my junk; I might be able to produce a wiring harness. Need anything else?
05-18-2010, 12:44 AM | #7 |
I have the xr harness. I think I may be missing a piece between the engine and the coil etc.
Going to make something to blend the lifan and honda wiring. Allen
05-18-2010, 02:27 AM | #8 |
This looks like a fun project, Allen. Thank you for posting the great photos! Please do keep us updated as your progress.
05-18-2010, 08:14 PM | #9 |
Since I am currently out of funds we will have to start with free things.
Part one will be stripping down to the frame and sanding/cleaning and prepping for paint. Plan will be to have it running for fall riding.
05-23-2010, 02:53 PM | #10 |
This could turn out to be a very nice bike when it's all said and done.
10-29-2010, 07:21 AM | #11 |
Okay. Since Doc is nearing completion. Here is my bike.
10-29-2010, 12:35 PM | #12 | |
I'm looking forward to your project. I think I will be able to help you as I've blazed some trails, like the battery mounting and the countershaft sprocket issue etc.
Happy to serve. |
10-29-2010, 05:27 PM | #13 |
I am seeing them. Does anyone else see the pics in the first post?
10-29-2010, 05:47 PM | #14 | |
10-30-2010, 09:29 AM | #15 |
Its just the first post.
I have some more pics of the engine. It appears to have dropped a valve and totalled the top end. W&G already claimed the parts. |
