flooding
Ok I got another used gya-200 idles fine then when you get up to 5 k rpm it sputters backfires and chokes out like its flooding. dies pull over sits for 15 min starts right up idles perfectly then when up to 45 starts sputtering backfiring.? help
My 200cc beast atv was doing something similar, turned out it was a bit lean, try lowering the jet needle clip a notch or two and try it again.
Also make sure the fuel cap is venting. Does is get better if you choke it?
I would check the fuel flow, it sounds like the fuel bowl on the carb may be going empty on you and not filling fast enough to keep up with the fuel demand, I have seen it before with clogged up petcocks and fuel filters. Or it could just be the carb needs a good cleaning out, this time of year is when everyone pulls the bikes out of storage and if they stored it with gas in the carb it will be gummed up.
#5 | |
![]() If you have an inline filter, it might be time to change it also.
ok
the only filter is one came with bike, looks clean, i can smell gas too much when riding, only happens when heats up and i get it up to 6krpm, had carb cleaned recently, lest they told me they did it.
kato
no Kato it doesnt do better with choke, no smoke, maybe lean carb?
Carb has been cleaned, doesn't improve with the choke, I am wondering if you may have a spark issue.
Did you check the sparkplug? Maybe its fouled. Allen
replaced
it was replaced at same time coil cable bad? possible coil?
#10 |
I would put more on a failing cdi unit, but a coil failure is possible.
Allen
#11 |
Does it rev fine in the lower gears? Sounds like a clogged air filter to me. Try cleaning the air filter, or replacing it.
2002 TA WS6, 2002 Chevy Avalanche, 2003 Bonneville SSEi, Hensim HS250DB Enduro |
#12 |
ok
have 3 cdi's have tried that, ill clean the air filter next, it runs fine till i wind it up. chokes and then backfires if i force it down the road
#13 |
part
anyone know where to get a coil, can i get a honda store?
#14 |
Is it a paper or foam filter element?
#15 |
oil fowled
If my oil is fowled that doesnt sound good
