Reading Plugs
I have had my Zong for just under a week. I am having a blast with it. I am trying to learn as much as fast as I can about these bikes. I have heard(read) people talk about reading plugs. I tried to do some research on it but would like some of your advice in regards to reading the plugs on these bikes. I have just under 200 miles on mine and pulled the plug today to look at it. Please tell me what you think as I have no clue.
![]() ![]() ![]() and here she is so Spud won't get mad because I didn't post a pic ![]() |
Good looking bike!
Your plug looks alright to me, if not a little 'light', but that could be splitting hairs...and really the ambient light and flash of the camera can be subjective there. What you don't want is for it to be white which means you're getting too much air and not enough fuel. (Lean) Running lean is worse for the motor than the alternative, which is 'rich'. If you're motor is running rich the plug would be black and carbon covered. Right now it looks tan and that's what you're aiming for. Well done! ![]() |
That is just the kind of advice I was looking for. Thanks Turbo
Yep, that looks pretty darn good. As for other info on reading plugs here's a good example of some plug conditions http://www.ngksparkplugs.com/tech_su...qs/faqread.asp
Zong looks awesome! On a side note, is that your baja bug? I had one just like that but hemi orange with black fenders
I was going to comment on the bug too. Looks like fun.
The plug looks good. Maybe alittle light. As you progress with the Spud mods :wink: , you will probably need to upjet the carb. Allen
yep I also agree your plug is good. was this taken out after hard running or just idling? the plug only shows about the last 30 seconds of engine running most of the time
Dune buggy build http://chinariders.net/modules.php?n...wtopic&t=14470 400cc lifan build vid: http://youtu.be/20HoU8OK_Y0 other fun: http://tinyurl.com/wildalaskan |
Thank you for posting the photo of your new Zong, Bama; she looks great!
![]() Spud ![]()
#9 | |
The bug is my other toy. I love it. It will go nearly anywhere it will fit. |
#10 |
I will admit, I am far from an expert regarding spark plug reading.
![]() http://www.thumpertalk.com/forum/thr...park-plug-chop http://faq.f650.com/FAQs/SparkPlugFAQ.htm Spud ![]()
#11 |
By doing a plug chop you ensure that the plug is not changed after you have tested at the intended throttle.
For example when testing at full throttle, for the main jet size, you would run at full throttle for a minimum of 30 seconds then hit the kill switch and pull the clutch simultaneously so fuel is no longer entering or burning in the engine, which would skew the results.
#12 | |
![]() http://faq.f650.com/FAQs/SparkPlugFAQ.htm#Plug%20Chop Finally, you remove the spark plug by the side of the road, and evaluate the color. Of course, you should begin with a brand new spark plug for each "plug chop." ![]() Spud ![]()
#13 |
yep you pretty much got it
#14 |
In my experience, that plug would indicate that you are rich, and quite a bit so. I don't think that plug reading is a reliable indicator of air fuel ratio with modern unleaded, alcohol enriched fuels. Not only that, these small bore single cylinder motors can exhibit some odd things at upper RPM's that would indicate a very lean situation, when in fact the very opposite is true.
Pull the plugs on your street car. Modern fuel management is quite good, but they do tend to run on the rich side for safety. Look at how white they are. My experience with race motors is that, by the time I got the plug looking a nice tan colour, I was 6-8 jet sizes too rich. If your bike is running OK, leave it. If you're not happy with it, go up 2 jet sizes at a time, until preformance drops off, then go back to the previous one. What would I do? Leave it. BTW, nice bike, and nice bug! |
#15 |
plug read
thanks,that also helps me,my zong plug is lighter than bama,s so he has nothing to worry about.And I am a at a 132.5 main jet
